查看: 1213|回复: 1
后仿真时的问题,求大神解决
ZHIXINhu 发表于 2014-5-27 21:13:47 | 显示全部楼层 |阅读模式
# Options:
#   -mindelays          Use minimum timing from min:typ:max expressions
#   -typdelays          Use typical timing from min:typ:max expressions (default)
#   -maxdelays          Use maximum timing from min:typ:max expressions
#   -delayscale <val>   Scale delays by the specified value
#   -nocompress         Don't compress the resulting output file
#   -suppress <msg(s)>  Suppress comma-separed list of error/warning messages
# Loading work.CYCLONE_PRIM_DFFE
# ** Warning: (vsim-SDF-3445) Failed to parse SDF file "frequence_divider_8_v.sdo".
#    Time: 0 ps  Iteration: 0  Instance: /tb_frequence_divider_8 File: E:/fpga project/frequence_divider_8/sim/tb_frequence_divider_8
# Error loading design
GMT+8, 2026-5-23 10:28 , Processed in 0.030960 second(s), 21 queries .
