查看: 1154|回复: 2
[北京]知名电信外企--FPGA Design & Verification Engineer
weimi 发表于 2014-6-2 13:18:21 | 显示全部楼层 |阅读模式
知名大型电信外企急招如下FPGA Design & Verification 职位,请联系:
weimi@ehanjia.com ,QQ:723839844
工作地点:北京
职位一:【FPGA Design Consultant Data communication】
Job Title:
FPGA Design Engineer
Job Objective:
To perform FPGA design and maintenance for Ericsson Telecommunication products
Responsibilities:
FPGA design with Verilog or VHDL.
Perform functional simulation and verification.
FPGA delivery and release, on board debug and testing.
Sustaining/maintenance support for FPGA issues for Voice and Data cards, BTS, BSC and Switching Products.
Documentation for related tasks also is responsible for document review, code inspection and other tasks required by quality process.
Qualifications & Requirements:
Good communication skills in English.
More than 3 years working experience on FPGA design in Telecommunication product field. IP broad band, ATM, data communication related experience.
Good Knowledge on FPGA design process and procedure.
Familiar with Verilog or VHDL, System Verilog is a plus.
Be familiar with standard HW protocol and interfaces and IO standards, PCI, PCI-e, SPI-4, SERDES, I2C, SGMII, and Flash/SDRAM.
Good understanding of IO timing, system/FPGA clocking, and system/FPGA reset structure and strategy.
Good sense of co-working with team members under CVS/ClearCase like source control environments is a plus.
Linux environment working capable is a plus; knowledge of script/Shell is a plus.
职位二、【 FPGA design Consultant Radio design (including RU and DU)】
Job Title:
Senior FPGA Design engineer
Job Objective:
To be responsible for Radio FPGA design, integration and maintenance.
Responsibilities:
Be responsible for Radio FPGA design, including DDC, DUC, RRC filter, CIC filter, sample rating mapping, and all external related interfaces.
Be responsible for related documentation of requirement, architecture, design specification and verification
Be responsible for FPGA design, verification and debugging.
At least three years working experience in digital IF design, graduated from Telecommunication, computing or related majors. Good telecommunication theory background.
Be familiar with digital IF design, be familiar high speed ADC, DAC and other external analog circuits, be familiar with radio structure and design methodology.
Be good at Verilog and VHDL coding and verification.
Be good at digital filter, frequency conversion, extraction, interpolation design, simulation and FPGA implementation
Be familiar with FPGA interface function and logic, high speed SERDES, parallel bus interfaces, serial bus interfaces.
Be good at English, reading, writing, speaking and listening.
职位三、【FPGA verification Engineer】
Job Title:
FPGA Verification Engineer (DV)
Job Objective:
To perform functional verification for FPGA designs
Responsibilities:
FPGA simulation and verification strategy planning and architecture design
Feature point extraction and test case planning and design and debugging.
More than 1 year working experience on FPGA verification in Telecommunication product field.
Good at C/C++ design, good understanding of OOP.
Knowledge and experience of FPGA design is a plus,
Knowledge of SystemVerilog is a plus.
Knowledge on verification methodology, OVM,UVM is a plus
Be familiar with standard protocol and interfaces and IO standards, PCI, PCI-e, Local bus, SERDES, CPRI, I2C, SGMII, Flash/SDRAM.
zhiweiqiang33 发表于 2014-6-3 16:25:15 | 显示全部楼层
可以了解一下
 楼主| weimi 发表于 2014-6-28 17:57:02 | 显示全部楼层
welcome to contact me....
GMT+8, 2026-5-23 20:33 , Processed in 0.042264 second(s), 20 queries .
