查看: 3322|回复: 3
夏老师书上的状态机例子仿真没有输出,请高手指点。
huangyijunok 发表于 2010-12-16 19:07:53 | 显示全部楼层 |阅读模式
主程序:
module writing ( reset,clk,address,data,sda,ack ) ;
  input reset ,clk ;
  input[7:0] address,data ;
  inout sda,ack;
  reg link_write ;
  reg [3:0] state ;
  reg [4:0] sh8out_state;
  reg [7:0] sh8out_buf ;
  reg finish_F;
  reg ack;
  parameter
    idle = 0 , addr_write = 1 ,data_write = 2 , stop_ack = 3 ;
  parameter
   bit0 = 1 , bit1 = 2 ,bit2 = 3 ,bit3 = 4 ,bit4 = 5 ,bit5 = 6 ,bit6 = 7 ,bit7 = 8 ;
   assign sda = link_write ? sh8out_buf[7]:1'bz;
   always @ ( posedge clk )
    if( !reset )
         link_write <= 0 ;
         state <= idle ;
         finish_F <= 0 ;
         sh8out_state <= idle ;
         ack <= 0 ;
         sh8out_buf <= 0 ;
     case ( state )
       idle :
           link_write  <= 0 ;
           finish_F <=0 ;
                ack <= 0 ;
           sh8out_buf <= address ;
           state <= addr_write ;
  addr_write:
          if ( finish_F == 0 )
           begin shift8_out ;
            sh8out_buf <= data ;
             state <= data_write ;
             finish_F <= 0 ;
   data_write:
           if(finish_F == 0)
            shift8_out ;
             link_write <= 0 ;
             state <= stop_ack ;
             finish_F <= 0 ;
              ack <= 1 ;
     stop_ack:
             ack <= 0 ;
             state <= idle ;
     endcase
  task shift8_out ;
       case ( sh8out_state )
       idle :
         link_write <= 1 ;
         sh8out_state <= bit7 ;
        bit7:
          link_write <= 1 ;
          sh8out_state <=bit6 ;
          sh8out_buf <= sh8out_buf << 1 ;
         bit6:
           sh8out_state <= bit5;
         bit5:
           sh8out_state <=bit4;
         bit4:
           sh8out_state <=bit3;
         bit3:
           sh8out_state <=bit2;
         bit2:
           sh8out_state <=bit1;
         bit1:
           sh8out_state <=bit0;
         bit0:
           link_write <= 0 ;
           finish_F <= 1 ;
       endcase
   endtask
   测试程序:
`timescale 1 ps/ 1 ps
`define clk_cycle 50
module writing_vlg_tst();
reg [7:0] address;
reg clk;
reg [7:0] data;
reg reset;
// wires
wire ack;
wire sda;
assign #`clk_cycle clk = ~clk ;
writing i1 (
// port map - connection between master ports and signals/registers
        .ack(ack),
        .address(address),
        .clk(clk),
        .data(data),
        .reset(reset),
        .sda(sda)
initial
  clk = 0 ;
  reset = 1 ;
  data = 0 ;
  address = 0 ;
  #( 2*`clk_cycle ) reset = 0 ;
  #( 2*`clk_cycle ) reset = 1 ;
  #( 100*`clk_cycle ) $stop ;
always  @ ( posedge ack )
  data = data + 1 ;
  address = address + 1 ;
编译后产生的警告:
Warning: The following nodes have both tri-state and non-tri-state drivers
        Warning: Inserted always-enabled tri-state buffer between "ack" and its non-tri-state driver.
Warning: TRI or OPNDRN buffers permanently enabled
        Warning: Node "ack~synth"
Warning: No exact pin location assignment(s) for 20 pins of 20 total pins
        Info: Pin sda not assigned to an exact location on the device
        Info: Pin ack not assigned to an exact location on the device
        Info: Pin clk not assigned to an exact location on the device
        Info: Pin data[7] not assigned to an exact location on the device
        Info: Pin address[7] not assigned to an exact location on the device
        Info: Pin reset not assigned to an exact location on the device
        Info: Pin data[6] not assigned to an exact location on the device
        Info: Pin address[6] not assigned to an exact location on the device
        Info: Pin data[5] not assigned to an exact location on the device
        Info: Pin address[5] not assigned to an exact location on the device
        Info: Pin data[4] not assigned to an exact location on the device
        Info: Pin address[4] not assigned to an exact location on the device
        Info: Pin data[3] not assigned to an exact location on the device
        Info: Pin address[3] not assigned to an exact location on the device
        Info: Pin data[2] not assigned to an exact location on the device
        Info: Pin address[2] not assigned to an exact location on the device
        Info: Pin data[1] not assigned to an exact location on the device
        Info: Pin address[1] not assigned to an exact location on the device
        Info: Pin data[0] not assigned to an exact location on the device
        Info: Pin address[0] not assigned to an exact location on the device
Warning: Found 2 output pins without output pin load capacitance assignment
        Info: Pin "sda" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
        Info: Pin "ack" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
Warning: Following 1 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results
        Info: Pin ack has a permanently enabled output enable
Warning: Found pins functioning as undefined clocks and/or memory enables
        Info: Assuming node "clk" is an undefined clock
wangxia6112 发表于 2010-12-17 11:18:27 | 显示全部楼层
这应该是I2C读写程序吧?我之前也写过一个,用了好长时间啊,主要还是时序的问题。
CPLD 发表于 2010-12-17 16:34:13 | 显示全部楼层
I2C 最好用自己的思想做出来
 楼主| huangyijunok 发表于 2010-12-18 21:09:24 | 显示全部楼层
前天搞了一天调试不出来,不知道书上的仿真图是怎么搞出来的(源程序是照着书上抄的),现在每天都在学习当中,希望到学到一定阶段这问题可以迎刃而解。望各位前辈多多指点,多谢!
补充一下:大家有没有用IIC对不同型号的的EEPROM进行页写和页读操作的经验,能否分享一下?
GMT+8, 2026-5-24 04:11 , Processed in 0.040979 second(s), 20 queries .
