查看: 1148|回复: 2
FPGA中怎么对芯片进行初始化
花开花落 发表于 2014-7-10 11:25:36 | 显示全部楼层 |阅读模式
就是说我有一个液晶的芯片,我怎么对控制它的读写时序,还有就是初始化如何控制,我看别人写的都是一堆case什么的,完全看不懂啊
 楼主| 花开花落 发表于 2014-7-12 08:56:43 | 显示全部楼层
laokai 发表于 2014-7-11 14:39
看不懂贴出来帮你解释!
好的,我贴出来
module        I2C_OV7670_Config
        input                [7:0]        LUT_INDEX,
        output        reg        [15:0]        LUT_DATA
parameter        Read_DATA        =        0;                        //Read data LUT Address
parameter        SET_OV7670        =        2;                        //SET_OV LUT Adderss
/////////////////////        Config Data LUT          //////////////////////////
always@(*)
        case(LUT_INDEX)
        //Audio Config Data
        //Read Data Index
//        Read_DATA + 0 :                LUT_DATA        =        {8'h0A, 8'h76};        //PID        ���̸�λʶ���� ��ֻ���
//        Read_DATA + 1 :                LUT_DATA        =        {8'h0B, 8'h73};        //VER        ���̵�λʶ���� ��ֻ���
        Read_DATA + 0 :                LUT_DATA        =        {8'h1C, 8'h7F};        //MIDH        ����ʶ���ֽ�-�ߣ�ֻ���
        Read_DATA + 1 :                LUT_DATA        =        {8'h1D, 8'hA2};        //MIDL        ����ʶ���ֽ�-�ͣ�ֻ���
        //OV7670 : VGA RGB565
        SET_OV7670 + 0         :         LUT_DATA        =         16'h3a04;        //16'h3a04
        SET_OV7670 + 1         :         LUT_DATA        =         16'h40d0;
        SET_OV7670 + 2         :         LUT_DATA        =         16'h1204;        //[4]������ʽ��QVGA [2]������ʽ��RGB {COM7[2], COM7[0]}={1,0} RGB  COM7[4]=1 ������ʹ��һ֡ͼ��ֻ�ɼ�240�У��൱��ֻ�ɼ��泡����ʱ��ͼ
        SET_OV7670 + 3         :         LUT_DATA        =         16'h32b6;        //16'h32b6
        SET_OV7670 + 4         :         LUT_DATA        =         16'h1713;        //
        SET_OV7670 + 5         :         LUT_DATA        =         16'h1801;        //
        SET_OV7670 + 6         :         LUT_DATA        =         16'h1902;        //
        SET_OV7670 + 7         :         LUT_DATA        =         16'h1a7a;        //
        SET_OV7670 + 8         :         LUT_DATA        =         16'h030a;        //
        SET_OV7670 + 9         :         LUT_DATA        =         16'h0c00;
        SET_OV7670 + 10 :         LUT_DATA        =         16'h3e00;
        SET_OV7670 + 11 :         LUT_DATA        =         16'h7000;        //00:Normal, 80:��λ1, 00:����, 80:��������
        SET_OV7670 + 12 :         LUT_DATA        =         16'h7100;        //00:Normal, 00:��λ1, 80:����, 80����������
        SET_OV7670 + 13 :         LUT_DATA        =         16'h7211;
        SET_OV7670 + 14 :         LUT_DATA        =         16'h7300;
        SET_OV7670 + 15 :         LUT_DATA        =         16'ha202;
        SET_OV7670 + 16 :         LUT_DATA        =         16'h1180;        //F���ڲ�ʱ�ӣ�=F������ʱ�ӣ�/��bit[5:0]+1��  range [00000]:[11111]
        SET_OV7670 + 17 :         LUT_DATA        =         16'h7a20;
        SET_OV7670 + 18 :         LUT_DATA        =         16'h7b1c;
        SET_OV7670 + 19 :         LUT_DATA        =         16'h7c28;
        SET_OV7670 + 20 :         LUT_DATA        =         16'h7d3c;
        SET_OV7670 + 21 :         LUT_DATA        =         16'h7e55;
        SET_OV7670 + 22 :         LUT_DATA        =         16'h7f68;
        SET_OV7670 + 23 :         LUT_DATA        =         16'h8076;
        SET_OV7670 + 24 :         LUT_DATA        =         16'h8180;
        SET_OV7670 + 25 :         LUT_DATA        =         16'h8288;
        SET_OV7670 + 26 :         LUT_DATA        =         16'h838f;
        SET_OV7670 + 27 :         LUT_DATA        =         16'h8496;
        SET_OV7670 + 28 :         LUT_DATA        =         16'h85a3;
        SET_OV7670 + 29 :         LUT_DATA        =         16'h86af;
        SET_OV7670 + 30 :         LUT_DATA        =         16'h87c4;
        SET_OV7670 + 31 :         LUT_DATA        =         16'h88d7;
        SET_OV7670 + 32 :         LUT_DATA        =         16'h89e8;
        SET_OV7670 + 33 :         LUT_DATA        =         16'h13e0;
        SET_OV7670 + 34 :         LUT_DATA        =         16'h0000;
        SET_OV7670 + 35 :         LUT_DATA        =         16'h1000;
        SET_OV7670 + 36 :         LUT_DATA        =         16'h0d00;
        SET_OV7670 + 37 :         LUT_DATA        =         16'h1428;        //
        SET_OV7670 + 38 :         LUT_DATA        =         16'ha505;
        SET_OV7670 + 39 :         LUT_DATA        =         16'hab07;
        SET_OV7670 + 40 :         LUT_DATA        =         16'h2475;
        SET_OV7670 + 41 :         LUT_DATA        =         16'h2563;
        SET_OV7670 + 42 :         LUT_DATA        =         16'h26a5;
        SET_OV7670 + 43 :         LUT_DATA        =         16'h9f78;
        SET_OV7670 + 44 :         LUT_DATA        =         16'ha068;
        SET_OV7670 + 45 :         LUT_DATA        =         16'ha103;
        SET_OV7670 + 46 :         LUT_DATA        =         16'ha6df;
        SET_OV7670 + 47 :         LUT_DATA        =         16'ha7df;
        SET_OV7670 + 48 :         LUT_DATA        =         16'ha8f0;
        SET_OV7670 + 49 :         LUT_DATA        =         16'ha990;
        SET_OV7670 + 50 :         LUT_DATA        =         16'haa94;
        SET_OV7670 + 51 :         LUT_DATA        =         16'h13ef;        //
        SET_OV7670 + 52 :         LUT_DATA        =         16'h0e61;
        SET_OV7670 + 53 :         LUT_DATA        =         16'h0f4b;
        SET_OV7670 + 54 :         LUT_DATA        =         16'h1602;
//        SET_OV7670 + 55 :         LUT_DATA        =         16'h1e01;//======16'h1e37
        SET_OV7670 + 56 :         LUT_DATA        =         16'h2102;
        SET_OV7670 + 57 :         LUT_DATA        =         16'h2291;
        SET_OV7670 + 58 :         LUT_DATA        =         16'h2907;
        SET_OV7670 + 59 :         LUT_DATA        =         16'h330b;
        SET_OV7670 + 60 :         LUT_DATA        =         16'h350b;
        SET_OV7670 + 61 :         LUT_DATA        =         16'h371d;
        SET_OV7670 + 62 :         LUT_DATA        =         16'h3871;
        SET_OV7670 + 63 :         LUT_DATA        =         16'h392a;
        SET_OV7670 + 64 :         LUT_DATA        =         16'h3c78;
        SET_OV7670 + 65 :         LUT_DATA        =         16'h4d40;
        SET_OV7670 + 66 :         LUT_DATA        =         16'h4e20;
        SET_OV7670 + 67 :         LUT_DATA        =         16'h6900;
//        SET_OV7670 + 68 :         LUT_DATA        =         16'h6b60;//========16'h6b60;
        SET_OV7670 + 69 :         LUT_DATA        =         16'h7419;
        SET_OV7670 + 70 :         LUT_DATA        =         16'h8d4f;
        SET_OV7670 + 71 :         LUT_DATA        =         16'h8e00;
        SET_OV7670 + 72 :         LUT_DATA        =         16'h8f00;
        SET_OV7670 + 73 :         LUT_DATA        =         16'h9000;
        SET_OV7670 + 74 :         LUT_DATA        =         16'h9100;
        SET_OV7670 + 75 :         LUT_DATA        =         16'h9200;
        SET_OV7670 + 76 :         LUT_DATA        =         16'h9600;
        SET_OV7670 + 77 :         LUT_DATA        =         16'h9a80;
        SET_OV7670 + 78 :         LUT_DATA        =         16'hb084;
        SET_OV7670 + 79 :         LUT_DATA        =         16'hb10c;
        SET_OV7670 + 80 :         LUT_DATA        =         16'hb20e;
        SET_OV7670 + 81 :         LUT_DATA        =         16'hb382;
        SET_OV7670 + 82 :         LUT_DATA        =         16'hb80a;
        SET_OV7670 + 83  :        LUT_DATA        =        16'h4314;
        SET_OV7670 + 84  :        LUT_DATA        =        16'h44f0;
        SET_OV7670 + 85  :        LUT_DATA        =        16'h4534;
        SET_OV7670 + 86  :        LUT_DATA        =        16'h4658;
        SET_OV7670 + 87  :        LUT_DATA        =        16'h4728;
        SET_OV7670 + 88  :        LUT_DATA        =        16'h483a;
        SET_OV7670 + 89  :        LUT_DATA        =        16'h5988;
        SET_OV7670 + 90  :        LUT_DATA        =        16'h5a88;
        SET_OV7670 + 91  :        LUT_DATA        =        16'h5b44;
        SET_OV7670 + 92  :        LUT_DATA        =        16'h5c67;
        SET_OV7670 + 93  :        LUT_DATA        =        16'h5d49;
        SET_OV7670 + 94  :        LUT_DATA        =        16'h5e0e;
        SET_OV7670 + 95  :        LUT_DATA        =        16'h6404;
        SET_OV7670 + 96  :        LUT_DATA        =        16'h6520;
        SET_OV7670 + 97  :        LUT_DATA        =        16'h6605;
        SET_OV7670 + 98  :        LUT_DATA        =        16'h9404;
        SET_OV7670 + 99  :        LUT_DATA        =        16'h9508;
        SET_OV7670 + 100 :        LUT_DATA        =        16'h6c0a;
        SET_OV7670 + 101 :        LUT_DATA        =        16'h6d55;
        SET_OV7670 + 102 :        LUT_DATA        =        16'h6e11;
        SET_OV7670 + 103 :        LUT_DATA        =        16'h6f9f;
        SET_OV7670 + 104 :        LUT_DATA        =        16'h6a40;
        SET_OV7670 + 105 :        LUT_DATA        =        16'h0140;
        SET_OV7670 + 106 :        LUT_DATA        =        16'h0240;
        SET_OV7670 + 107 :        LUT_DATA        =        16'h13e7;
        SET_OV7670 + 108 :        LUT_DATA        =        16'h1500;
        SET_OV7670 + 109 :        LUT_DATA        =         16'h4f80;
        SET_OV7670 + 110 :        LUT_DATA        =         16'h5080;
        SET_OV7670 + 111 :        LUT_DATA        =         16'h5100;
        SET_OV7670 + 112 :        LUT_DATA        =         16'h5222;
        SET_OV7670 + 113 :        LUT_DATA        =         16'h535e;
        SET_OV7670 + 114 :        LUT_DATA        =         16'h5480;
        SET_OV7670 + 115 :        LUT_DATA        =         16'h589e;
        SET_OV7670 + 116 :         LUT_DATA        =        16'h4108;
        SET_OV7670 + 117 :         LUT_DATA        =        16'h3f00;
        SET_OV7670 + 118 :         LUT_DATA        =        16'h7505;
        SET_OV7670 + 119 :         LUT_DATA        =        16'h76e1;
        SET_OV7670 + 120 :         LUT_DATA        =        16'h4c00;
        SET_OV7670 + 121 :         LUT_DATA        =        16'h7701;
        SET_OV7670 + 122 :         LUT_DATA        =        16'h3dc2;
        SET_OV7670 + 123 :         LUT_DATA        =        16'h4b09;
        SET_OV7670 + 124 :         LUT_DATA        =        16'hc960;
        SET_OV7670 + 125 :         LUT_DATA        =        16'h4138;
        SET_OV7670 + 126 :         LUT_DATA        =        16'h5640;
        SET_OV7670 + 127 :         LUT_DATA        =        16'h3411;
        SET_OV7670 + 128 :         LUT_DATA        =        16'h3b02;
        SET_OV7670 + 129 :         LUT_DATA        =        16'ha489;        //
        SET_OV7670 + 130 :         LUT_DATA        =        16'h9600;
        SET_OV7670 + 131 :         LUT_DATA        =        16'h9730;
        SET_OV7670 + 132 :         LUT_DATA        =        16'h9820;
        SET_OV7670 + 133 :         LUT_DATA        =        16'h9930;
        SET_OV7670 + 134 :         LUT_DATA        =        16'h9a84;
        SET_OV7670 + 135 :         LUT_DATA        =        16'h9b29;
        SET_OV7670 + 136 :         LUT_DATA        =        16'h9c03;
        SET_OV7670 + 137 :         LUT_DATA        =        16'h9d4c;
        SET_OV7670 + 138 :         LUT_DATA        =        16'h9e3f;
        SET_OV7670 + 139 :         LUT_DATA        =        16'h7804;
        SET_OV7670 + 140 :        LUT_DATA        =        16'h7901;
        SET_OV7670 + 141 :        LUT_DATA        =         16'hc8f0;
        SET_OV7670 + 142 :        LUT_DATA        =         16'h790f;
        SET_OV7670 + 143 :        LUT_DATA        =         16'hc800;
        SET_OV7670 + 144 :        LUT_DATA        =         16'h7910;
        SET_OV7670 + 145 :        LUT_DATA        =         16'hc87e;
        SET_OV7670 + 146 :        LUT_DATA        =         16'h790a;
        SET_OV7670 + 147 :        LUT_DATA        =         16'hc880;
        SET_OV7670 + 148 :        LUT_DATA        =         16'h790b;
        SET_OV7670 + 149 :        LUT_DATA        =         16'hc801;
        SET_OV7670 + 150 :        LUT_DATA        =         16'h790c;
        SET_OV7670 + 151 :        LUT_DATA        =         16'hc80f;
        SET_OV7670 + 152 :        LUT_DATA        =         16'h790d;
        SET_OV7670 + 153 :        LUT_DATA        =         16'hc820;
        SET_OV7670 + 154 :        LUT_DATA        =         16'h7909;
        SET_OV7670 + 155 :        LUT_DATA        =         16'hc880;
        SET_OV7670 + 156 :        LUT_DATA        =         16'h7902;
        SET_OV7670 + 157 :        LUT_DATA        =         16'hc8c0;
        SET_OV7670 + 158 :        LUT_DATA        =         16'h7903;
        SET_OV7670 + 159 :        LUT_DATA        =         16'hc840;
        SET_OV7670 + 160 :        LUT_DATA        =         16'h7905;
        SET_OV7670 + 161 :        LUT_DATA        =         16'hc830;
        SET_OV7670 + 162 :        LUT_DATA        =         16'h7926;
        SET_OV7670 + 163 :        LUT_DATA        =         16'h0903;
        SET_OV7670 + 164 :        LUT_DATA        =         16'h3b42;
        default                          :        LUT_DATA        =        0;
        endcase
这个是通过SCCB对ov7670进行初始化,有些寄存器不知道如何配置,我看了datasheet只需要配置16个就行了
GMT+8, 2026-5-23 10:31 , Processed in 0.033805 second(s), 20 queries .
