查看: 1435|回复: 2
FPGA实现UART收发器
羽蒙 发表于 2014-7-13 16:51:19 | 显示全部楼层 |阅读模式
module UART ( rst,clk50M,send_en,rev_en,TXD,TXD_data,RXD,RXD_data);
input rst,clk50M,RXD,send_en,rev_en;
input [7:0] TXD_data;
output TXD;
reg TXD;
reg [7:0] TXD_cnt;
output [7:0] RXD_data;
reg [7:0] RXD_data;
reg [7:0] RXD_cnt;
parameter baud=9600;        //any baud is OK;
//frediv = fclk/(16*baud)
//e.g. fclk=50M,9600 baud,frediv=326
/*parity check
even parity:1'b0 XOR d[0] ~ d[7];
odd parity :1'b1 XOR d[0] ~ d[7];
reg [11:0] fre_cnt;
reg clk_baud;
always@(negedge rst or posedge clk50M)
        if(!rst)
                fre_cnt<=1'b0;
                if(clk50M)
                        if(fre_cnt==(50000000/(16*baud)))
                                fre_cnt<=1'b0;
                                fre_cnt<=fre_cnt+1'b1;
                                if(fre_cnt<=(50000000/(16*baud))/2)
                                        clk_baud<=1'b1;
                                        clk_baud<=1'b0;
always@(negedge rst or posedge clk_baud)
        if(!rst)
                TXD_cnt<=1'd0;
                TXD<=1'b1;
                if(clk_baud)
                        if(send_en)
                                case(TXD_cnt)
                                        8'd0        :        begin
        TXD<=1'b0;
        TXD_cnt<=TXD_cnt+8'd1;
                                        8'd16        :         begin
        TXD<=TXD_data[0];
                                        8'd32        :         begin
        TXD<=TXD_data[1];
                                        8'd48        :         begin
        TXD<=TXD_data[2];
                                        8'd64        :         begin
        TXD<=TXD_data[3];
                                        8'd80        :         begin
        TXD<=TXD_data[4];
                                        8'd96        :         begin
        TXD<=TXD_data[5];
                                        8'd112        :         begin
        TXD<=TXD_data[6];
                                        8'd128        :         begin
        TXD<=TXD_data[7];
                                        8'd144        :         begin
        TXD<=1'b1;
                                        8'd160        :        TXD_cnt<=8'd0;
                                        default        :        TXD_cnt<=TXD_cnt+8'd1;
                                endcase
                                TXD<=1'b1;
                                TXD_cnt<=8'd0;
        if(!rst)
                RXD_cnt<=1'd0;
                if(clk_baud)
                        if(rev_en)
                                case(RXD_cnt)
                                        8'd0        :        if(!RXD)
        RXD_cnt<=RXD_cnt+8'd1;
        RXD_cnt<=8'd0;
                                        8'd16        :         begin
        RXD_data[0]<=RXD;
                                        8'd32        :         begin
        RXD_data[1]<=RXD;
                                        8'd48        :         begin
        RXD_data[2]<=RXD;
                                        8'd64        :         begin
        RXD_data[3]<=RXD;
                                        8'd80        :         begin
        RXD_data[4]<=RXD;
                                        8'd96        :         begin
        RXD_data[5]<=RXD;
                                        8'd112        :         begin
        RXD_data[6]<=RXD;
                                        8'd128        :         begin
        RXD_data[7]<=RXD;
                                        8'd144        :         if(RXD)
        RXD_cnt<=8'd144;
                                        8'd160        :        RXD_cnt<=8'd0;
                                        default        :        RXD_cnt<=RXD_cnt+8'd1;
                                endcase
                                RXD_cnt<=8'd0;
zhiweiqiang33 发表于 2014-7-15 17:13:17 | 显示全部楼层
多谢分享 很实用
fpga_feixiang 发表于 2025-10-23 13:50:12 | 显示全部楼层
FPGA实现UART收发器
GMT+8, 2026-5-22 14:27 , Processed in 0.031175 second(s), 20 queries .
