查看: 1147|回复: 0
Vivado HLS学习资料
羽蒙 发表于 2014-7-18 14:06:00 | 显示全部楼层 |阅读模式
第一, 手边的学习资料。 安装Vivado HLS以后, 既包含了20个design example,50个code example: 附件:[[wysiwyg_imageupload:950:]]                     第二, step by step教程 ug871 是xilinx公开提供的HLS教程, 包括11个例子: C ValidationInterface SynthesisArbitrary Precision TypesDesign AnalysisDesign OptimizationRTL VerificationUsing HLS IP in IP IntegratorUsing HLS IP in a Zynq Processor DesignUsing HLS IP in System Generator for DSP ug871 :http://www.xilinx.com/support/do ... h-level-synthesi... 参考设计源代码:http://www.xilinx.com/cgi-bin/do ... ;t=vivado+tutorials 附件:[[wysiwyg_imageupload:951:]] 第三, 13个Xilinx专家讲解视频, 包括讲座和演示 地址: www.xilinx.com/training/vivado 1.Getting Started with Vivado High-Level Synthesis2.Verifying your Vivado HLS Design3.Packaging Vivado HLS IP for use from Vivado IP Catalog4.Generating Vivado HLS block for use in System Generator for DSP5.Generating Vivado HLS pcore for use in Xilinx Platform Studio6.Analyzing your Vivado HLS design7.Specifying AXI4 interfaces for your Vivado HLS design8.Using Vivado HLS C/C++/SystemC block in System Generator9.Using Vivado HLS C/C++/SystemC based pcores in XPS10.Floating-Point Design with Vivado HLS11.Using Vivado HLS SW libraries in your C, C++, SystemC code12.Using the Vivado HLS Tclinterface13.LeveragingOpenCVand High Level Synthesis with Vivado 第四, 不停更新的武林秘籍 www.xilinx.com/hls
XAPP745 Processor Control of Vivado HLS Designs
XAPP793 Implementing Memory Structures for Video Processing in the Vivado HLS Tool
XAPP599Floating Point Design with Vivado HLS
XAPP890 Zynq All Programmable SoC Sobel Filter Implementation Using the Vivado HLSTool
XAPP1163 - Floating-Point PID Controller Design with Vivado HLS and System Generator forDSP
XAPP1167Accelerating OpenCV Applications with Zynq using Vivado HLS Video Libraries 附件:[[wysiwyg_imageupload:952:]]
GMT+8, 2026-5-23 19:11 , Processed in 0.036698 second(s), 20 queries .
