查看: 1605|回复: 1
DM368启动串口打印分析_3
zhiweiqiang33 发表于 2014-9-9 10:06:32 | 显示全部楼层 |阅读模式
FR : 0 users registered from exsiting face album //0用户注册从现存的脸专辑
IPNC_DM368_3.1.0 (root@localhost.localdomain) (gcc version 4.2.
IPNC AUTO_IRIS = 1
log status
portmapstart_daemon
entry drv_imgs_MT9M034_1.2MP.c DRV_imgsEnable //驱动影响的ID
log success
log status
log status
Starting mounting local filesystems: log status //开始安装的本地文件系统:日志状态
mount none on /dev/shm type tmpfs (rw,size=5M) //挂载none在/dev/shm, 文件系统类型tmpfs
none on /var/run type tmpfs (rw)
none on /tmp type tmpfs (rw,sync)
log success
log status
Starting hotplug subsystem: //启动热拔插子系统:
ApproDrvInit: 9
queue id:131076
Initializing...
...done initializing
ApproDrvInit: 8
queue id:131076
Initializing...
ApproDrvInit: 2
queue id:131076
Initializing...
Play this stream using the URL: //播放视频流
rtsp://192.168.0.168:8553/PSIA/S ... ideoCodecType=MPEG4
(We use port 8300 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 6
queue id:131076
Initializing...
rtsp://192.168.0.168:8554/PSIA/S ... ideoCodecType=MPEG4
(We use port 8301 for optional RTSP-over-HTTP tunneling.)
ApproDrvInit: 10
queue id:131076
Initializing...
rtsp://192.168.0.168:8557/PSIA/S ... ideoCodecType=H.264
(We use port 8304 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.0.168:8556/PSIA/S ... ideoCodecType=H.264
(We use port 8303 for optional RTSP-over-HTTP tunneling.)
rtsp://192.168.0.168:8555/PSIA/S ... ideoCodecType=MJPEG
(We use port 8302 for optional RTSP-over-HTTP tunneling.)
usb
usb [success]
input
exit drv_imgs_MT9M034_1.2MP.c DRV_imgsEnable
input [success]
done.
TI AWB PRODUCTION VERSION 1.0.0
[ 12.550000] loop: loaded (max 8 devices)
Simple mixer control 'PGA',0
Capabilities: cvolume
Capture channels: Mono
Limits: Capture 0 - 3
Mono: Capture 2 [67%]
Simple mixer control 'Mono DAC',0
Capabilities: pvolume pvolume-joined
Playback channels: Mono
Limits: Playback 0 - 63
Mono: Playback 47 [75%]
sycOnvif Profile 1
[ 13.120000] tun: Universal TUN/TAP device driver, 1.6
SystemInit succe[ 13.120000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ss
Schedule manager init success
[ 13.620000] CSLIP: code copyright 1989 Regents of the University of California
[ 13.840000] netconsole: not configured, aborting
[ 14.030000] PPP generic driver version 2.4.2
[ 14.490000] PPP Deflate Compression module registered
Starting internet superserver: inetd.
[ 15.620000] sbulla: unknown partition table
insmod: /opt/ipnc/modules/des.ko: No such file or directory
insmod: /opt/ipnc/modules/md5.ko: No such file or directory
[ 17.450000] davinci-mmc davinci-mmc.0: Supporting 4-bit mode
[ 17.460000] davinci-mmc davinci-mmc.0: Using DMA mode
[ 18.190000] usbcore: registered new driver usbfs
[ 18.430000] usbcore: registered new driver hub
[ 18.770000] musb_hdrc: version 6.0, cppi-dma, peripheral, debug=0
[ 18.950000] musb_hdrc musb_hdrc: No DMA interrupt line
[ 18.950000] musb_hdrc: USB Peripheral mode controller at c38f8000 using DMA, IRQ 12
[ 19.360000] Loading iSCSI transport class v1.1-646.<5>iscsi: registered transport (tcp)
[ 20.910000] sbulla: unknown partition table
mkdosfs 3.0.6 (04 Oct 2009)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
Root directory contains 512 slots.
Volume ID is 0162947e, no volume label.
queue id:0
umount: /mnt/mmc: not mounted
mount: /dev/mmcblk0 is not a valid block device
mount: /dev/mmcblk0p1 is not a valid block device
dns=192.168.0.1
net_search_gateway:eth0, A8C0, 0, 1
net_search_gateway:eth0, 0, FE00A8C0, 3
dns=192.168.0.1
ERROR: Module g_file_storage does not exist in /proc/modules
[ 23.970000] g_file_storage gadget: File-backed Storage Gadget, version: 28 November 2005
[ 23.990000] g_file_storage gadget: Number of LUNs=1
[ 24.000000] g_file_storage gadget-lun0: ro=0, file: /dev/sbulla
[ 24.280000] system_server/280[CPU#0]: BUG in local_bh_enable at kernel/softirq.c:196
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
queue id:0
[01/Jan/1970:00:00:24 +0000] boa: server version Boa/0.94.13
[01/Jan/1970:00:00:24 +0000] boa: server built Aug 28 2013 at 10:06:37.
[01/Jan/1970:00:00:24 +0000] boa: starting server pid=685, port 80
UDPString=uuid:Upnp-TVEmulator-1_0-00_0017252061</UDN>
Upnp port is 0
UPnP Initialized OK ip=192.168.0.168, port=49152
desc_doc_url = http://192.168.0.168/tvdevicedesc.xml
error code = 0
INIT: Entering runlevel: 5
de
MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774)
192 login: root (automatic login)
Welcome to MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774).
login[717]: root login on `ttyS0'
 楼主| zhiweiqiang33 发表于 2017-6-9 10:33:00 | 显示全部楼层
希望这些资料信息对大家有所帮助
GMT+8, 2026-5-23 03:37 , Processed in 0.033199 second(s), 20 queries .
