查看: 1819|回复: 0
PS/2程序源码
vvt 发表于 2011-1-28 08:17:10 | 显示全部楼层 |阅读模式
PS/2程序源码
entity mouse is
Port (clk : in std_logic; reset : in std_logic; ps2_clk : inout std_logic; ps2_data : inout std_logic; left_button : out std_logic; right_button : out std_logic; mousex: buffer std_logic_vector(9 downto 0); mousey: buffer std_logic_vector(9 downto 0); data_ready : out std_logic; error_no_ack : out std_logic);
end mouse;
architecture Behavioral of mouse is
--变量、信号定义(略)
ps2_clk <= '0' when ps2_clk_hi_z='0' else 'Z';
ps2_data <= '0' when ps2_data_hi_z='0' else 'Z';
--检测ps2clk上升沿和下降沿(略)
m2statech: process (reset, clk) ------------------m2 状态
if (reset='0') then
m2_state <= m2_reset;
elsif (clk'event and clk='1') then
m2_state <= m2_next_state;
end if;
end process;
--m2 状态传输逻辑
m2statetr: process (m2_state, q, fall,rise,watchdog_timer_done,bitcount,ps2_data,packet_good)
ps2_clk_hi_z <= '1';
ps2_data_hi_z <= '1';
error_no_ack <= '0';
output_strobe <= '0';
case m2_state is
when m2_reset => -- 复位后向鼠标发送命令字
m2_next_state <= m2_hold_clk_l;
when m2_wait =>
if (fall='1') then
m2_next_state <= m2_gather;
m2_next_state <= m2_wait;
end if;
when m2_gather =>
if ((watchdog_timer_done='1') and (bitcount=TOTAL_BITS))then
m2_next_state <= m2_verify;
end if;
when m2_verify =>
--if (bitcount < TOTAL_BITS) then
--m2_next_state <= m2_wait;
--else
m2_next_state <= m2_use;
--end if;
when m2_use =>
output_strobe <= '1';
-- 用状态机的9个状态实现命令字传输,使鼠标进入"streaming"模式,并等待鼠标正确应答
when m2_hold_clk_l =>
ps2_clk_hi_z <= '0'; -- 启动看门狗!
if (watchdog_timer_done='1') then
m2_next_state <= m2_data_low_1;
end if;
when m2_data_low_1 =>
ps2_data_hi_z <= '0'; -- 数据位 开始位, d[0] and d[1]
if (fall='1' and (bitcount = 2)) then
m2_next_state <= m2_data_high_1;
end if;
when m2_data_high_1 =>
ps2_data_hi_z <= '1'; -- 数据位 d[2]
if (fall='1' and (bitcount = 3)) then
m2_next_state <= m2_data_low_2;
end if;
when m2_data_low_2 =>
ps2_data_hi_z <= '0'; -- 数据位 d[3]
if (fall='1' and (bitcount = 4)) then
m2_next_state <= m2_data_high_2;
end if;
when m2_data_high_2 =>
ps2_data_hi_z <= '1'; -- 数据位 d[4],d[5],d[6],d[7]
if (fall='1' and (bitcount = 8)) then
m2_next_state <= m2_data_low_3;
end if;
when m2_data_low_3 =>
ps2_data_hi_z <= '0'; -- 奇偶校验位
if (fall='1') then
m2_next_state <= m2_data_high_3;
end if;
when m2_data_high_3 =>
ps2_data_hi_z <= '1'; -- 允许鼠标拉成低电平(ACK脉冲)
if (fall='1' and (ps2_data='1')) then
m2_next_state <= m2_error_no_ack;
elsif (fall='1' and (ps2_data='0')) then
m2_next_state <= m2_await_response;
end if;
when m2_error_no_ack =>
error_no_ack <= '1';
-- 为了鼠标正确进入"streaming"模式,状态极必须等待足够长的时间,确保鼠标正确应答0xFA。
when m2_await_response =>
--if (bitcount = 22) then
--else
-- m2_next_state <= m2_await_response;
--end if;
when others => m2_next_state <= m2_wait;
end case;
end process;-----------------------------m2 状态结束
-- 位计数器 (略)
-- 数据移位寄存器(略)
-- 看门狗时间计数器(略)
watchdog_timer_done <= '1' when (watchdog_timer_count=WATCHDOG-1) else '0';
packet_good <= '1'; -- 接收数据包有效标志
outdata: process (reset, clk) -- 输出数据
if (reset='0') then
left_button <= '0';
right_button <= '0';
if (output_strobe='1') then
left_button <= q(1);
right_button <= q(2);
mouseyy <= not (q(6) & q(6) & q(30 downto 23)) + "1";
end if;
end if;
end process;
cordinatex: process (reset, clk)
if (reset='0') then
mousex <= "0110010000"; -- 400
if ((mousex >= 797 and q(5)='0') or (mousex <= 2 and
q(5)='1')) then
mousex <= mousex;
mousex <= mousex + (q(5) & q(5) & q(19 downto
12));--q(5):xsign q(6):ysign
end if;
end if;
end if;
end process;
cordinatey: process (reset, clk)
if (reset='0') then
mousey <= "0100101100"; -- 300
if ((mousey >= 597 and q(6)='1') or (mousey <= 2
and q(6)='0')) then
mousey <= mousey;
m ousey <= mousey + mouseyy; --(q(6) & q(6) & q(30
downto 23));
end if;
end if;
end if;
end process;
data_ready <= output_strobe;
end Behavioral;
结束语
  该设计采用了清华大学THCII-1创新SoPC实验套件进行综合、仿真和下载,测试得到了满意的效果,完整地实现了对PS/2和VGA的时序驱动。
  该设计可以被应用到各种需要鼠标操作、以VGA作为显示的嵌入式系统中,从而大大提高人机交互能力,降低了开发成本,提高了开发效率,使系统的稳定性也得到了可靠的保障。
GMT+8, 2026-5-24 02:46 , Processed in 0.031072 second(s), 20 queries .
