查看: 1816|回复: 0
关于ISE仿真出现的问题,请高人指教
kshparadise 发表于 2011-2-10 20:52:25 | 显示全部楼层 |阅读模式
warn:the design contains one or more registers/latches that are directly incompatible with the spartan6 architecture.the two primary causes of this is either a register or latch described with beth an asynchronous set and asynchronous reset.or a register or catch described with an asynchronous polarity
请问用IES仿真VHDL时 出现以上的警告,这样对结果会不会产生影响呢
GMT+8, 2026-5-24 02:46 , Processed in 0.039464 second(s), 21 queries .
