查看: 1633|回复: 1
大家知道这个程序是做什么用的吗
zhouliang 发表于 2011-2-16 13:40:02 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all        ;
use ieee.std_logic_arith.all;
entity twice is
port (clk,rst:in std_logic;
       clk_temp:inout std_logic;
       d_out:inout std_logic;
       d_outn:inout std_logic;
       clk_outut std_logic);
end twice;
architecture rtl of twice is
process(clk_temp,rst)
        if(rst='1') then
                d_out<='0';
                if(clk_temp'event and clk_temp='1') then
                        d_out<=d_outn;
                end if;
        end if;
end process;
clk_temp<=clk xor d_out;
clk_out<=clk_temp;
d_outn<=not d_out;
end rtl;
zhoujunxia 发表于 2011-5-10 09:43:41 | 显示全部楼层
D触发器哈!
GMT+8, 2026-5-24 00:39 , Processed in 0.051559 second(s), 20 queries .
