查看: 2169|回复: 0
2011年传感器最新报价
andersonli 发表于 2011-2-22 16:15:32 | 显示全部楼层 |阅读模式
最近搜集的2011年传感器最新的市场价格,希望对大家有帮助,如大家需要了解更多的电子元器件价格,可以到我的数据库网站看一下,网址是http://www.icbom.com/
产品型号        产品描述        价格($)
MMA7455LT        IC ACCELEROMETER 3AXIS 14-LGA        1.273
MMA8450QT        IC ACCEL I2C 2G/4G/8G 16QFN        1.976
MMA2301EGR2        IC SENSOR ACCEL +/-200G 16-SOIC        2.512
MMA3202EGR2        SENSOR ACCEL +/-100/50G 20-SOIC        3.404
MMA3202EGR2        SENSOR ACCEL +/-100/50G 20-SOIC        7.402
MMA1220EG        IC SENSOR ACCEL +/-8G 16-SOIC        5.599
MMA2202EG        SENS ACCEL X-AXIS +/-50G 16-SOIC        6.253
MMA2201EG        SENSOR ACCEL X-AXIS+/-40G 16SOIC        4.816
MMA1260EG        SENSOR ACCEL Z-AXIS 1.5G 16-SOIC        5.984
MMA1270EG        IC ACCELEROMETER Z AXIS 16-SOIC        6.545
MMA3201EG        IC SENSOR ACCEL +/-40G 20-SOIC        8.044
MMA3202EG        SENSOR ACCEL +/-100/50G 20-SOIC        8.281
MMA7330LR1        IC ACCELEROMETER 3AXIS 14-LGA
MMA7330LR1        IC ACCELEROMETER 3AXIS 14-LGA        3.248
MMA7340LR1        IC ACCELEROMETER 3AXIS 14-LGA
MMA7340LR1        IC ACCELEROMETER 3AXIS 14-LGA        3.944
MMA6281QR2        IC ACCELEROMETER XZ AXIS 16-QFN
MMA6281QR2        IC ACCELEROMETER XZ AXIS 16-QFN        4.626
MMA1270EGR2        IC ACCELEROMETER Z AXIS 16-SOIC        3.282
MMA1270EGR2        IC ACCELEROMETER Z AXIS 16-SOIC        4.878
MMA1260EGR2        SENSOR ACCEL Z-AXIS 1.5G 16-SOIC        3.635
MMA1260EGR2        SENSOR ACCEL Z-AXIS 1.5G 16-SOIC        7.333
MMA7660FCT        ACCELEROMETER 3X3 DGTL 10-DFN        1.057
MMA6331LT        SENSORS ACCELEROMETER 14LGA        1.222
MMA1212EG        IC ACCELEROMETER Z AXIS 16-SOIC        4.195
MMA2301EG        IC SENSOR ACCEL +/-200G 16-SOIC        5.07
MMA2204EG        SENSOR ACCEL X-AX +/-100G 16SOIC        5.999
MMA7660FCR1        ACCELEROMETER 3X3 DGTL 10-DFN        0.607
MMA7455LR1        IC ACCELEROMETER 3AXIS 14-LGA        0.651
MMA7455LR2        IC ACCELEROMETER 3AXIS 14-LGA        0.629
MMA7368LR1        ACCELEROMETER 1.5G 3AXIS 14-LGA        0.978
MMA7368LR2        ACCELEROMETER 1.5G 3AXIS 14-LGA        1.12
MMA7368LT        ACCELEROMETER 1.5G 3AXIS 14-LGA        1.009
MMA7341LT        ACCELEROMETER TRPL 3.3V 14-LGA        1.153
MMA7331LR1        ACCELEROMETER 4G XYZ ENH 14-LGA        0.995
MMA7331LR2        ACCELEROMETER 4G XYZ ENH 14-LGA        1.09
MMA7341LR1        ACCELEROMETER 3G XYZ ENH 14-LGA        0.901
MMA7341LR2        ACCELEROMETER 3G XYZ ENH 14-LGA        0.869
MMA7361LR1        ACCELEROMETER 1.5G XYZ 14-LGA        0.901
MMA7361LR2        ACCELEROMETER 1.5G XYZ 14-LGA        0.901
MMA7331LCT        SENS ACCELEROMETER 3AXIS 14LGA        1.242
MMA7361LCT        SENS ACCELEROMETER 3AXIS 14LGA        1.106
MMA2202EGR2        SENSOR ACCEL X-AXIS 50G 16-SOIC        3.285
MMA2204EGR2        SENSOR ACCEL X-AXIS 100G 16-SOIC        2.829
MMA2201EGR2        SENSOR ACCEL +/-40G 16-SOIC        2.601
GMT+8, 2026-5-24 06:21 , Processed in 0.033406 second(s), 20 queries .
