查看: 1324|回复: 0
DDS任意信号发生器
wudi123baobei 发表于 2014-11-12 20:04:47 | 显示全部楼层 |阅读模式
/*信号定义
inclock:时钟
control:控制产生波形的种类,为00,01,10,11时,分别产生正弦波、方波、三角波和锯齿波;
i:控制读取时间间隔,调整频率
q_out:输出数据*/
module signal_gene(inclock,q_out,control,i);
input inclock;
output [7:0] q_out;
input [1:0] control;  //控制产生波形的种类
input [3:0] i;
reg[8:0] address;
wire[7:0] q_out;
reg[7:0] m,k;
reg[1:0] state;
rom rom_component(.address(address),
                          .clock(inclock),
        .q(q_out)
always @(posedge inclock)
  case(state)
  0:begin    //产生正弦波形
     if(control==1) address<=9'd128;
     if(control==2) address<=9'd256;
          if(control==3) address<=9'd384;
     if(i==0||i==1) begin
            address<=address+1'b1;
                 if(address>=9'd127) address<=9'd0;
                 else begin
                     k<=127/i;m<=i*k;
                          address<=address+i;
                          if(address>=m) address<=9'd0;
        1:begin   //产生锯齿波形
          if(control==0)  address<=9'd0;
          if(address<128) address<=9'd128;
           else begin
              if(i==0||i==1)begin
                         if(address==9'd255) address<=9'd128;
                  else begin
                     k<=127/i;m<=i*k;
                          address<=address+i;
                          if(address>=m+9'd128) address<=9'd128;
        2:begin  //产生方波形
                if(address<9'd256) address<=9'd256;
                  else begin
              if(i==0||i==1)begin
                         if(address==9'd383) address<=9'd256;
                  else begin
                     k<=127/i;m<=i*k;
                          address<=address+i;
                          if(address>=m+256) address<=9'd256;
                3:begin    //产生三角波形
          if(address<384) address<=9'd384;
          else begin
                 if(address==9'd511) address<=9'd384;
                 else begin
                     k<=127/i;m<=i*k;
                          address<=address+i;
                          if(address>=m+384) address<=9'd384;
                endcase
测试文件:
`timescale 1 ps/ 1 ps
module signal_gene_vlg_tst();
reg [1:0] control;
reg [3:0] i;
reg inclock;
// wires
wire [7:0]  q_out;
// assign statements (if any)
signal_gene i1 (
// port map - connection between master ports and signals/registers
        .control(control),
        .i(i),
        .inclock(inclock),
        .q_out(q_out)
initial
inclock=0;
i=4'b0000;
control=2'b00;
#100 control=2'b11;
#100 control=2'b10;
#100000 $finish;
always  #10 inclock=~inclock;
GMT+8, 2026-5-23 09:53 , Processed in 0.031114 second(s), 20 queries .
