查看: 1913|回复: 0
跪求大牛释疑 Reduced register BCD[31] with stuck data_in port to stuck value GND
wangxc 发表于 2011-2-23 10:24:44 | 显示全部楼层 |阅读模式
小弟初学FPGA,写个程序但仿真没有结果输出,跪求高人赐教,万分感激!
仿真中发现程序中BIN_INPUT <= to_bitvector(BIN);没有被执行,或者说BIN_INPUT 始终为零,很是不解,同时发现发现编译中出一些类似Warning : Reduced register "BCD[31]" with stuck data_in port to stuck value GND的警告,不知两者是否有关系,望高人赐教。具体程序如下:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity BIN2BCD_Conv_vhdl is
                port(
                            CLK :in std_logic;
                                EN_Conv :in std_logic;
                                nRST :in std_logic;
                                BIN :in std_logic_vector(31 downto 0);
                                oBCD ut std_logic_vector(31 downto 0)
end BIN2BCD_Conv_vhdl;
architecture behav of BIN2BCD_Conv_vhdl is
  signal CNT:integer range 0 to 50;
  signal  ENABLE :std_logic;
-- signal  BIN_tmp:std_logic_vector(31 downto 0);
  signal  BCD_I:bit_vector(31 downto 0);
  signal  BIN_INPUT :bit_vector(31 downto 0);
  signal  BIN_INPUT_tmp1,BIN_INPUT_tmp2:std_logic_vector(31 downto 0);
  signal  BIN_INPUT_H,BIN_INPUT_M,BIN_INPUT_S :bit_vector(7 downto 0);
function CORRECT(DECADE:in bit_vector(3 downto 0))return
          bit_vector is
        variable oData:bit_vector(3 downto 0);
        variable oData_tmp,DECADE_tmp:std_logic_vector(3 downto 0);
    DECADE_tmp :=to_stdlogicvector(DECADE);
    if(DECADE_tmp >= x"5")then
                oData_tmp :=(DECADE_tmp+b"0011");
             oData_tmp :=DECADE_tmp;
         end if;
        oData :=to_bitvector(oData_tmp);
  return oData;
  end function CORRECT;
  oBCD <=to_stdlogicvector(BCD_I);
process(CLK,nRST)
    if(nRST='0')then
                        BIN_INPUT_tmp1 <= x"0000_0000";
                        BIN_INPUT_tmp2 <= x"0000_0001";
           elsif(CLK'event and CLK='1')then
                      BIN_INPUT_tmp2 <=BIN_INPUT_tmp1;
                          BIN_INPUT_tmp1 <= BIN;
          end if;
end process;
process(CLK)
if(CLK'event and CLK='0')then
  if(BIN_INPUT_tmp1 = BIN_INPUT_tmp2)then
           ENABLE <='0';
       ENABLE <='1';
    end if;
  end if;
end process;
process(CLK,nRST,BIN,ENABLE)
variable  BCD:bit_vector(31 downto 0);
variable  BCD_H,BCD_M,BCD_S :bit_vector(7 downto 0);
        if(nRST='0')then
    --     BCD := x"0000_0000";
         BIN_INPUT <= x"0000_0000";
         BCD_I <= x"0000_0000";
                 BCD_H := x"00";
                 BCD_M := x"00";
                 BCD_S := x"00";
         BIN_INPUT_H <=x"00";
                 BIN_INPUT_M <= x"00";
                 BIN_INPUT_S <= x"00";
                  if(EN_Conv='1')then
                           if(ENABLE='1')then
                                          CNT <=9;
                                          BCD_H := x"00";
                                          BCD_M := x"00";
                                          BCD_S := x"00";
                                   end if;
                                if(CNT =9)then
                                                BIN_INPUT_H <=to_bitvector(BIN(23 downto 16));
                                                BIN_INPUT_M <=to_bitvector(BIN(15 downto 8));
                                                BIN_INPUT_S <=to_bitvector(BIN(7 downto 0));
                                                CNT <= CNT -1;
                                        elsif(CNT=0)then
                                                BCD_I(23 downto 0) <= (BCD_H&BCD_M&BCD_S);
                               BCD_H(3 downto 0) := CORRECT(BCD_H(3 downto 0));
                               BCD_H(7 downto 4) := CORRECT(BCD_H(7 downto 4));
                               CNT <= CNT -1;--conversion section
                               BCD_H := (BCD_H srl 1);
                               BCD_H(0) := BIN_INPUT_H(7);
                               BIN_INPUT_H <= BIN_INPUT_H srl 1;
                                                           BCD_M(3 downto 0) := CORRECT(BCD_M(3 downto 0));
                               BCD_M(7 downto 4) := CORRECT(BCD_M(7 downto 4));
                               BCD_M := (BCD_M srl 1);
                               BCD_M(0) := BIN_INPUT_M(7);
                               BIN_INPUT_M <= BIN_INPUT_M srl 1;
                                                           BCD_S(3 downto 0) := CORRECT(BCD_S(3 downto 0));
                               BCD_S(7 downto 4) := CORRECT(BCD_S(7 downto 4));
                               BCD_S := (BCD_S srl 1);
                               BCD_S(0) := BIN_INPUT_S(7);
                               BIN_INPUT_S <= BIN_INPUT_S srl 1;
                                        end if;
                                if(ENABLE='1')then
                                                CNT <=33;
                                                BCD :=x"0000_0000";
                                   end if;
                                if(CNT =33)then
                          CNT <= CNT -1;
                                         elsif(CNT = 0)then
        BCD_I <= BCD;
                               BCD(3 downto 0) := CORRECT(BCD(3 downto 0));
                               BCD(7 downto 4) := CORRECT(BCD(7 downto 4));
                               BCD(11 downto 8) := CORRECT(BCD(11 downto 8));
                               BCD(15 downto 12) := CORRECT(BCD(15 downto 12));
                                                           BCD(19 downto 16) := CORRECT(BCD(19 downto 16));
                                                           BCD(23 downto 20) := CORRECT(BCD(23 downto 20));
                                                           BCD(27 downto 24) := CORRECT(BCD(27 downto 24));
                                                           BCD(31 downto 28) := CORRECT(BCD(31 downto 28));
                               BCD := (BCD srl 1);
                               BCD(0) := BIN_INPUT(31);
                               BIN_INPUT <= BIN_INPUT srl 1;
                   end if;
                                end if;
          end if;
end process;
end behav;
GMT+8, 2026-5-24 04:11 , Processed in 0.031555 second(s), 21 queries .
