查看: 1448|回复: 1
做一个按键自加自减的程序,出现了显示问题。
pdmonster 发表于 2014-12-4 17:04:27 | 显示全部楼层 |阅读模式
顶层文件
module led_jj_seg(
    input               clock ,
    input               reset ,
    input        key1        ,
    input        key2        ,
    output                                                seg_led_a,
    output                                                seg_led_b,
    output                                                seg_led_c,
    output                                                seg_led_d,
    output                                                seg_led_e,
    output                                                seg_led_f,
    output                                                seg_led_g,
    output                                                seg_led_dp,
    output                                                seg_led_dig1,
    output                                                seg_led_dig2,
    output                                                seg_led_dig3,
    output                                                seg_led_dig4,
    output        [3:0]                        LED
// SIGNALS
wire  [13:0]    counter;
wire        [3:0]                        seg_s;
wire        [7:0]                        seg;
//wire            clock_200hz;
//wire            clock_10hz;
assign LED[3:0] = 4'b0000;
// CODE
// SUBMODULE
led_jj u_led_jj(
                 .clock      (clock)   ,
                 .reset                  (reset)   ,
                 .counter           (counter) ,
                 .key1                         (key1)           ,
                 .key2       (key2)
dyn_seg u_dyn_seg (
                   .clock         (clock_200hz),
                   .reset                      (reset),
                   .data                       (counter),
                   .seg_s               (seg_s),
                   .seg                        (seg)
// clk_gen u_clk_gen(
//                                      .clock      (clock) ,
//                                      .reset        (reset) ,
//                                      .clock_200hz  (clock_200hz) ,
//                                .clock_10hz   (clock_10hz)
assign seg_led_a = seg[0];
assign seg_led_b = seg[1];
assign seg_led_c = seg[2];
assign seg_led_d = seg[3];
assign seg_led_e = seg[4];
assign seg_led_f = seg[5];
assign seg_led_g = seg[6];
assign seg_led_dp = seg[7];
assign seg_led_dig1 = seg_s[0];
assign seg_led_dig2 = seg_s[1];
assign seg_led_dig3 = seg_s[2];
assign seg_led_dig4 = seg_s[3];
自加、自减文件
module led_jj(
    input               clock ,
    input               reset ,
    input        key1        ,
         input        key2        ,
                 output                reg [13:0]                counter
reg                [1:0]                key_xiaodou;
reg                [1:0]                key_xiaodou_yanchi;
reg                [19:0]        count;
reg                [1:0]                key_cunchu;
reg                [1:0]                key_cunchu_yanchi;
reg                [1:0]                temp;
wire        [1:0]                key_xiaodou_chucun;
wire        [1:0]                key_cunchu_chucun;
always @(posedge clock or negedge reset)
                if(!reset)begin
                        key_xiaodou        <= 2'b11;
                        key_xiaodou_yanchi        <= 2'b11;
                else begin
                        key_xiaodou <= {key2,key1};
                        key_xiaodou_yanchi <= key_xiaodou;
assign                         key_xiaodou_chucun = key_xiaodou_yanchi & (~key_xiaodou);
                if(!reset)
                        count <= 20'd0;                                //测试下位宽改变有无影响
                else if(key_xiaodou_chucun)
                        count <= 20'd0;
                        count <= count+1'd1;
                if(!reset)begin
                        key_cunchu                <= 2'b11;
                        key_cunchu_yanchi <= 2'b11;
                else if(count == 20'hfffff)begin
                        key_cunchu <= {key2,key1};
                else begin
                        key_cunchu_yanchi <= key_cunchu;
assign                         key_cunchu_chucun = key_cunchu_yanchi & (~key_cunchu);
always @ (posedge clock or negedge reset)
    if (!reset) begin
        counter    <= 14'b0;
    else begin
        if (counter==14'd9999) begin
            counter    <= 14'b0;
        else begin
                temp = key_cunchu_chucun;
            case(temp)
            2'b01 : counter <= counter+14'b1 ;
                               2'b10 : counter <= counter-14'b1 ;
                               default:;
                                endcase
显示文件
//****************************************Copyright 2014[c]************************// *
// ************************Declaration***************************************//
// File name:        dyn_seg.v        //
// Author:           buck.feng@link-real.com.cn                             //
// Date:             2014-03-21 15:18                                        //
// Version Number:   1.0                                                     //
// Abstract:
// Modification history:[including time, version, author and abstract]        //
// 2014-03-21 15:18         version 1.0     xxx                                //
// Abstract: Initial                                                          //
// *********************************end************************************** //
`timescale      1ns/100ps
// MODULE DEFINTION
module dyn_seg(
    input               clock     ,
    input               reset ,
    input       [13:0]  data    ,
    output  reg [3:0]   seg_s   ,
    output  reg [7:0]   seg
// SIGNALS
reg     [1:0]   count_show    ;
wire    [3:0]   data0       ;
wire    [3:0]   data1       ;
wire    [3:0]   data2       ;
wire    [3:0]   data3       ;
reg     [3:0]   hex         ;
// CODE
assign data0 = data/1000;
assign data1 = data%1000/100;
assign data2 = data%100/10;
assign data3 = data%10;
always @ (negedge reset or posedge clock)
    if (!reset) begin
        count_show    <= 2'b0;
    else begin
        count_show    <= count_show+2'b1;
    if(!reset) begin
        seg_s   <= 4'b0;
    else begin
        case(count_show[1:0])
            2'b00 : seg_s <= 4'b0001;
            2'b01 : seg_s <= 4'b0010;
            2'b10 : seg_s <= 4'b0100;
            2'b11 : seg_s <= 4'b1000;
            default: ;
        endcase
always @ (*)
        2'b00 : hex <= data0;
        2'b01 : hex <= data1;
        2'b10 : hex <= data2;
        2'b11 : hex <= data3;
        default:hex <= 4'b0;
    endcase
    if (!reset) begin
        seg     <= 8'b0;
    else begin
        case(hex)
            4'h0: seg   <= 8'b11000000;
            4'h1: seg   <= 8'b11111001;
            4'h2: seg   <= 8'b10100100;
            4'h3: seg   <= 8'b10110000;
            4'h4: seg   <= 8'b10011001;
            4'h5: seg   <= 8'b10010010;
            4'h6: seg   <= 8'b10000010;
            4'h7: seg   <= 8'b11111000;
            4'h8: seg   <= 8'b10000000;
            4'h9: seg   <= 8'b10010000;
            4'hA: seg   <= 8'b01110111;
            4'hB: seg   <= 8'b01111100;
            4'hC: seg   <= 8'b00111001;
            4'hD: seg   <= 8'b01011110;
            4'hE: seg   <= 8'b01111001;
            4'hF: seg   <= 8'b01110001;
            default: ;
        endcase
//// SUBMODULE
程序在上面,但是显示出来后 数码管的数字不对
Cherrycar 该用户已被删除
Cherrycar 发表于 2014-12-6 10:08:41 | 显示全部楼层
试一试把二进制转bcd码模块改一下,直接相除取余速度是非常慢的
GMT+8, 2026-5-23 09:53 , Processed in 0.031750 second(s), 21 queries .
