查看: 1134|回复: 1
数字信号采集 串口 FPGA 遇到问题求大神指点
yjj455202641 发表于 2014-12-12 10:47:01 | 显示全部楼层 |阅读模式
我想实现数字信号采集,并通过串口发送出去,能用串口接收上位机指令,控制采集。下面是我用quartus ii 软件编的程序,但是不好使,请大神指点!
module yiwei(clk1,in8,en,rst1,out8,rclk,ren,rx);
input clk1,en;
input rst1;
input [7:0]in8;
input rclk;
input ren;
output [7:0]out8;
output rx;
reg [3:0] cnt;
reg [7:0] Q;
wire line8;
reg[4:0]WREG;
reg[4:0]RREG;
reg wen;
initial Q=0;
assign out8=Q;
always @(posedge clk1 or negedge rst1)
        if(!rst1)
   Q<=0;
        else if(en)
                        Q<=in8;
        if(!rst1) WREG=0;
        else if(en)
                if(WREG<8)
                WREG<=WREG+1;
                else WREG<=0;
   else WREG<=0;
always @(posedge rclk)
        if(ren)
                if(RREG<8)
                RREG<=RREG+1;
                else RREG<=0;
        else RREG<=0;
        arm4 my_ram(
                .data(out8),
                .rdaddress(RREG),
                .rdclock(rclk),
                .rden(ren),
                .wraddress(WREG),
                .wrclock(clk1),
                .wren(en),
                .q(line8)
        UART_RX myRX(
                .sys_clk(rclk),
                .reset_rx,
                .Rx_start(ren),
                .Rx(rx),
                .Rx_Data(line8),
                .Rx_Reg()
子模块
module UART_RX(
                                sys_clk,reset_rx,Rx_start,Rx,Rx_Data,Rx_Reg
                input sys_clk,reset_rx,Rx,Rx_start;
                output Rx_Reg;
                output [7:0]Rx_Data;
                reg[7:0]Rx_Data;
                reg Rx_Reg;
parameter SYS_CLK=50000000;//50M系统时钟
parameter Rx_bps=9600;
parameter Rxdata_w=12;
parameter RXCLK_DATA=SYS_CLK/Rx_bps-1;//波特率分频器分频值
reg [Rxdata_w-1:0]clk_cnt;
reg EN_RXCLK;
wire RX_CLK;    //波特率时钟
always @(posedge sys_clk or negedge reset_rx)
        if(!reset_rx)
                clk_cnt<=12'd0;
        else if(!EN_RXCLK)
                clk_cnt<=12'd0;
        else if(clk_cnt==RXCLK_DATA)
                clk_cnt<=12'd0;
        else clk_cnt<=clk_cnt+1;
assign RX_CLK=(clk_cnt==0);//产生发送时钟
reg [3:0] RxState;
reg [9:0] RxTemp;//
        if(!reset_rx)
        RxState=4'd0;
        Rx_Data=8'd0;
        RxTemp=10'd0;//
        Rx_Reg=1'b0;
        EN_RXCLK=1'b0;
        else if((Rx_Reg==0)&&(RxState==0)&&Rx_start)
        EN_RXCLK=1'b1;
        RxState<=4'd1;
        else if(RX_CLK)
                case(RxState)
                        4'd1: begin
                                        RxTemp[0]<=Rx;
                                        RxState<=4'd2;
                        4'd2:begin
                                        RxTemp[1]<=Rx;
                                        RxState<=4'd3;
                        4'd3:begin
                                        RxTemp[2]<=Rx;
                                        RxState<=4'd4;
                        4'd4:begin
                                        RxTemp[3]<=Rx;
                                        RxState<=4'd5;
                        4'd5:begin
                                        RxTemp[4]<=Rx;
                                        RxState<=4'd6;
                        4'd6:begin
                                        RxTemp[5]<=Rx;
                                        RxState<=4'd7;
                        4'd7:begin
                                        RxTemp[6]<=Rx;
                                        RxState<=4'd8;
                        4'd8:begin
                                        RxTemp[7]<=Rx;
                                        RxState<=4'd9;
                        4'd9:begin
                                        RxTemp[8]<=Rx;//结束位
                                        RxState<=4'd0;
                                        EN_RXCLK<=1'b0;
                                        if(RxTemp[8])
                                                Rx_Data<=RxTemp[7:0];
                                           Rx_Reg=1'b1;
                        endcase
                else Rx_Reg=1'b0;
还有这个模块
// megafunction wizard: %RAM: 2-PORT%
// GENERATION: STANDARD
// VERSION: WM1.0
// MODULE: altsyncram
// File Name: arm4.v
// Megafunction Name(s):
//                         altsyncram
// Simulation Library Files(s):
//                         altera_mf
// THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
// 11.0 Build 208 07/03/2011 SP 1 SJ Full Version
//Copyright (C) 1991-2011 Altera Corporation
//Your use of Altera Corporation's design tools, logic functions
//and other software and tools, and its AMPP partner logic
//functions, and any output files from any of the foregoing
//(including device programming or simulation files), and any
//associated documentation or information are expressly subject
//to the terms and conditions of the Altera Program License
//Subscription Agreement, Altera MegaCore Function License
//Agreement, or other applicable license agreement, including,
//without limitation, that your use is for the sole purpose of
//programming logic devices manufactured by Altera and sold by
//Altera or its authorized distributors.  Please refer to the
//applicable agreement for further details.
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module arm4 (
        data,
        rdaddress,
        rdclock,
        rden,
        wraddress,
        wrclock,
        wren,
        q);
        input        [7:0]  data;
        input        [4:0]  rdaddress;
        input          rdclock;
        input          rden;
        input        [4:0]  wraddress;
        input          wrclock;
        input          wren;
        output        [7:0]  q;
`ifndef ALTERA_RESERVED_QIS
`endif
        tri1          rden;
        tri1          wrclock;
        tri0          wren;
`endif
        wire [7:0] sub_wire0;
        wire [7:0] q = sub_wire0[7:0];
        altsyncram        altsyncram_component (
                                .address_a (wraddress),
                                .clock0 (wrclock),
                                .data_a (data),
                                .rden_b (rden),
                                .wren_a (wren),
                                .address_b (rdaddress),
                                .clock1 (rdclock),
                                .q_b (sub_wire0),
                                .aclr0 (1'b0),
                                .aclr1 (1'b0),
                                .addressstall_a (1'b0),
                                .addressstall_b (1'b0),
                                .byteena_a (1'b1),
                                .byteena_b (1'b1),
                                .clocken0 (1'b1),
                                .clocken1 (1'b1),
                                .clocken2 (1'b1),
                                .clocken3 (1'b1),
                                .data_b ({8{1'b1}}),
                                .eccstatus (),
                                .q_a (),
                                .rden_a (1'b1),
                                .wren_b (1'b0));
        defparam
                altsyncram_component.address_reg_b = "CLOCK1",
                altsyncram_component.clock_enable_input_a = "BYPASS",
                altsyncram_component.clock_enable_input_b = "BYPASS",
                altsyncram_component.clock_enable_output_a = "BYPASS",
                altsyncram_component.clock_enable_output_b = "BYPASS",
                altsyncram_component.intended_device_family = "Cyclone II",
                altsyncram_component.lpm_type = "altsyncram",
                altsyncram_component.maximum_depth = 128,
                altsyncram_component.numwords_a = 32,
                altsyncram_component.numwords_b = 32,
                altsyncram_component.operation_mode = "DUAL_PORT",
                altsyncram_component.outdata_aclr_b = "NONE",
                altsyncram_component.outdata_reg_b = "UNREGISTERED",
                altsyncram_component.power_up_uninitialized = "FALSE",
                altsyncram_component.rdcontrol_reg_b = "CLOCK1",
                altsyncram_component.widthad_a = 5,
                altsyncram_component.widthad_b = 5,
                altsyncram_component.width_a = 8,
                altsyncram_component.width_b = 8,
                altsyncram_component.width_byteena_a = 1;
// CNX file retrieval info
// Retrieval info: PRIVATE: ADDRESSSTALL_A NUMERIC "0"
// Retrieval info: PRIVATE: ADDRESSSTALL_B NUMERIC "0"
// Retrieval info: PRIVATE: BYTEENA_ACLR_A NUMERIC "0"
// Retrieval info: PRIVATE: BYTEENA_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_ENABLE_A NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_ENABLE_B NUMERIC "0"
// Retrieval info: PRIVATE: BYTE_SIZE NUMERIC "8"
// Retrieval info: PRIVATE: BlankMemory NUMERIC "1"
// Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_A NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_INPUT_B NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_A NUMERIC "0"
// Retrieval info: PRIVATE: CLOCK_ENABLE_OUTPUT_B NUMERIC "0"
// Retrieval info: PRIVATE: CLRdata NUMERIC "0"
// Retrieval info: PRIVATE: CLRq NUMERIC "0"
// Retrieval info: PRIVATE: CLRrdaddress NUMERIC "0"
// Retrieval info: PRIVATE: CLRrren NUMERIC "0"
// Retrieval info: PRIVATE: CLRwraddress NUMERIC "0"
// Retrieval info: PRIVATE: CLRwren NUMERIC "0"
// Retrieval info: PRIVATE: Clock NUMERIC "1"
// Retrieval info: PRIVATE: Clock_A NUMERIC "0"
// Retrieval info: PRIVATE: Clock_B NUMERIC "0"
// Retrieval info: PRIVATE: ECC NUMERIC "0"
// Retrieval info: PRIVATE: ECC_PIPELINE_STAGE NUMERIC "0"
// Retrieval info: PRIVATE: IMPLEMENT_IN_LES NUMERIC "0"
// Retrieval info: PRIVATE: INDATA_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: INDATA_REG_B NUMERIC "0"
// Retrieval info: PRIVATE: INIT_FILE_LAYOUT STRING "PORT_B"
// Retrieval info: PRIVATE: INIT_TO_SIM_X NUMERIC "0"
// Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone II"
// Retrieval info: PRIVATE: JTAG_ENABLED NUMERIC "0"
// Retrieval info: PRIVATE: JTAG_ID STRING "NONE"
// Retrieval info: PRIVATE: MAXIMUM_DEPTH NUMERIC "128"
// Retrieval info: PRIVATE: MEMSIZE NUMERIC "256"
// Retrieval info: PRIVATE: MEM_IN_BITS NUMERIC "0"
// Retrieval info: PRIVATE: MIFfilename STRING ""
// Retrieval info: PRIVATE: OPERATION_MODE NUMERIC "2"
// Retrieval info: PRIVATE: OUTDATA_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: OUTDATA_REG_B NUMERIC "0"
// Retrieval info: PRIVATE: RAM_BLOCK_TYPE NUMERIC "0"
// Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_MIXED_PORTS NUMERIC "2"
// Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_A NUMERIC "3"
// Retrieval info: PRIVATE: READ_DURING_WRITE_MODE_PORT_B NUMERIC "3"
// Retrieval info: PRIVATE: REGdata NUMERIC "1"
// Retrieval info: PRIVATE: REGq NUMERIC "1"
// Retrieval info: PRIVATE: REGrdaddress NUMERIC "1"
// Retrieval info: PRIVATE: REGrren NUMERIC "1"
// Retrieval info: PRIVATE: REGwraddress NUMERIC "1"
// Retrieval info: PRIVATE: REGwren NUMERIC "1"
// Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
// Retrieval info: PRIVATE: USE_DIFF_CLKEN NUMERIC "0"
// Retrieval info: PRIVATE: UseDPRAM NUMERIC "1"
// Retrieval info: PRIVATE: VarWidth NUMERIC "0"
// Retrieval info: PRIVATE: WIDTH_READ_A NUMERIC "8"
// Retrieval info: PRIVATE: WIDTH_READ_B NUMERIC "8"
// Retrieval info: PRIVATE: WIDTH_WRITE_A NUMERIC "8"
// Retrieval info: PRIVATE: WIDTH_WRITE_B NUMERIC "8"
// Retrieval info: PRIVATE: WRADDR_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: WRADDR_REG_B NUMERIC "0"
// Retrieval info: PRIVATE: WRCTRL_ACLR_B NUMERIC "0"
// Retrieval info: PRIVATE: enable NUMERIC "0"
// Retrieval info: PRIVATE: rden NUMERIC "1"
// Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
// Retrieval info: CONSTANT: ADDRESS_REG_B STRING "CLOCK1"
// Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_A STRING "BYPASS"
// Retrieval info: CONSTANT: CLOCK_ENABLE_INPUT_B STRING "BYPASS"
// Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_A STRING "BYPASS"
// Retrieval info: CONSTANT: CLOCK_ENABLE_OUTPUT_B STRING "BYPASS"
// Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone II"
// Retrieval info: CONSTANT: LPM_TYPE STRING "altsyncram"
// Retrieval info: CONSTANT: MAXIMUM_DEPTH NUMERIC "128"
// Retrieval info: CONSTANT: NUMWORDS_A NUMERIC "32"
// Retrieval info: CONSTANT: NUMWORDS_B NUMERIC "32"
// Retrieval info: CONSTANT: OPERATION_MODE STRING "DUAL_PORT"
// Retrieval info: CONSTANT: OUTDATA_ACLR_B STRING "NONE"
// Retrieval info: CONSTANT: OUTDATA_REG_B STRING "UNREGISTERED"
// Retrieval info: CONSTANT: POWER_UP_UNINITIALIZED STRING "FALSE"
// Retrieval info: CONSTANT: RDCONTROL_REG_B STRING "CLOCK1"
// Retrieval info: CONSTANT: WIDTHAD_A NUMERIC "5"
// Retrieval info: CONSTANT: WIDTHAD_B NUMERIC "5"
// Retrieval info: CONSTANT: WIDTH_A NUMERIC "8"
// Retrieval info: CONSTANT: WIDTH_B NUMERIC "8"
// Retrieval info: CONSTANT: WIDTH_BYTEENA_A NUMERIC "1"
// Retrieval info: USED_PORT: data 0 0 8 0 INPUT NODEFVAL "data[7..0]"
// Retrieval info: USED_PORT: q 0 0 8 0 OUTPUT NODEFVAL "q[7..0]"
// Retrieval info: USED_PORT: rdaddress 0 0 5 0 INPUT NODEFVAL "rdaddress[4..0]"
// Retrieval info: USED_PORT: rdclock 0 0 0 0 INPUT NODEFVAL "rdclock"
// Retrieval info: USED_PORT: rden 0 0 0 0 INPUT VCC "rden"
// Retrieval info: USED_PORT: wraddress 0 0 5 0 INPUT NODEFVAL "wraddress[4..0]"
// Retrieval info: USED_PORT: wrclock 0 0 0 0 INPUT VCC "wrclock"
// Retrieval info: USED_PORT: wren 0 0 0 0 INPUT GND "wren"
// Retrieval info: CONNECT: @address_a 0 0 5 0 wraddress 0 0 5 0
// Retrieval info: CONNECT: @address_b 0 0 5 0 rdaddress 0 0 5 0
// Retrieval info: CONNECT: @clock0 0 0 0 0 wrclock 0 0 0 0
// Retrieval info: CONNECT: @clock1 0 0 0 0 rdclock 0 0 0 0
// Retrieval info: CONNECT: @data_a 0 0 8 0 data 0 0 8 0
// Retrieval info: CONNECT: @rden_b 0 0 0 0 rden 0 0 0 0
// Retrieval info: CONNECT: @wren_a 0 0 0 0 wren 0 0 0 0
// Retrieval info: CONNECT: q 0 0 8 0 @q_b 0 0 8 0
// Retrieval info: GEN_FILE: TYPE_NORMAL arm4.v TRUE
// Retrieval info: GEN_FILE: TYPE_NORMAL arm4.inc FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL arm4.cmp FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL arm4.bsf FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL arm4_inst.v FALSE
// Retrieval info: GEN_FILE: TYPE_NORMAL arm4_bb.v TRUE
// Retrieval info: LIB_FILE: altera_mf
 楼主| yjj455202641 发表于 2014-12-12 10:53:15 | 显示全部楼层
大神如果有可以实现此功能的程序就更好了,我编的可能有一些问题。
GMT+8, 2026-5-23 09:53 , Processed in 0.031947 second(s), 21 queries .
