查看: 1258|回复: 0
关于SRAM/FRAM接口设计的问题求助
lqtcagsn 发表于 2014-12-15 19:56:14 | 显示全部楼层 |阅读模式
目前使用的quartus版本为12.1
FPGA为cyclone5系列 5CEBA4U15C8N
FRAM为 Cypress: FM21LD16-60(2Mbit)
附上FRAM datasheet的部分和我设计的测试部分
烧进板子后用nios执行得到的就是“Verify failed between address xx and oo”的错误。对于FRAM的接口设计和使用不是很有把握,可能会有很多低级错误还望指教。
另附上FRAM的tcl代码
# TCL File Generated by Component Editor 12.1sp1
# Mon Dec 15 20:44:28 JST 2014
# DO NOT MODIFY
# SRAM "IS61WV51216" v1.0
# me 2014.12.15.20:44:28
# 16bit SRAM Interface
# request TCL package from ACDS 11.0
package require -exact sopc 11.0
# module SRAM
set_module_property DESCRIPTION "16bit SRAM Interface"
set_module_property NAME SRAM
set_module_property VERSION 1.0
set_module_property INTERNAL false
set_module_property OPAQUE_ADDRESS_MAP true
set_module_property GROUP SRAM
set_module_property AUTHOR me
set_module_property ICON_PATH output_files/
set_module_property DISPLAY_NAME IS61WV51216
set_module_property TOP_LEVEL_HDL_FILE output_files/
set_module_property INSTANTIATE_IN_SYSTEM_MODULE false
set_module_property EDITABLE true
set_module_property ANALYZE_HDL AUTO
set_module_property FIX_110_VIP_PATH false
set_module_property REPORT_TO_TALKBACK false
set_module_property ALLOW_GREYBOX_GENERATION false
# files
# file sets
# parameters
# display items
# connection point avalon_tristate_slave
add_interface avalon_tristate_slave avalon_tristate end
set_interface_property avalon_tristate_slave activeCSThroughReadLatency false
set_interface_property avalon_tristate_slave associatedClock ""
set_interface_property avalon_tristate_slave explicitAddressSpan 262144
set_interface_property avalon_tristate_slave holdTime 1
set_interface_property avalon_tristate_slave isMemoryDevice true
set_interface_property avalon_tristate_slave isNonVolatileStorage false
set_interface_property avalon_tristate_slave maximumPendingReadTransactions 0
set_interface_property avalon_tristate_slave printableDevice false
set_interface_property avalon_tristate_slave readLatency 0
set_interface_property avalon_tristate_slave readWaitTime 1
set_interface_property avalon_tristate_slave setupTime 0
set_interface_property avalon_tristate_slave timingUnits Cycles
set_interface_property avalon_tristate_slave writeWaitStates 1
set_interface_property avalon_tristate_slave writeWaitTime 1
set_interface_property avalon_tristate_slave ENABLED true
add_interface_port avalon_tristate_slave addr address Input 17
add_interface_port avalon_tristate_slave data data Bidir 16
add_interface_port avalon_tristate_slave ncs chipselect_n Input 1
add_interface_port avalon_tristate_slave wrn write_n Input 1
add_interface_port avalon_tristate_slave rdn read_n Input 1
add_interface_port avalon_tristate_slave ben byteenable_n Input 2
set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isFlash 0
set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isMemoryDevice 1
set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isNonVolatileStorage 0
set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isPrintableDevice 0
GMT+8, 2026-5-23 09:53 , Processed in 0.032863 second(s), 22 queries .
