查看: 1180|回复: 2
哪位大神指导下列程序错在哪?
dj120110 发表于 2015-1-12 19:20:33 | 显示全部楼层 |阅读模式
一个8分频,输出恒为高电平
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
ENTITY EVEN_DIVIDER IS
GENERIC(N:INTEGER :=8);
PORT(
CLKIN: IN STD_LOGIC;
CLKOUT:OUT STD_LOGIC;
CNT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0)
END EVEN_DIVIDER;
ARCHITECTURE RTL OF EVEN_DIVIDER IS
SIGNAL COUNT:INTEGER;
BEGIN
        PROCESS (CLKIN)
                BEGIN
                        IF CLKIN'EVENT AND CLKIN='1' THEN
                                IF COUNT=N-1 THEN
                                        COUNT<=0;
                                ELSE
                                        COUNT<=COUNT+1;
                                        IF COUNT<4 THEN
                                                CLKOUT<='1';
                                        ELSE
                                                CLKOUT<='0';
                                        END IF;
                                END IF;
                        END IF;
        END PROCESS;
        CNT<=CONV_STD_LOGIC_VECTOR(COUNT,3);
END RTL;
 楼主| dj120110 发表于 2015-1-12 20:30:58 | 显示全部楼层
自己顶起,希望有人帮助解答
 楼主| dj120110 发表于 2015-1-13 13:12:40 | 显示全部楼层
已找到原因,未赋初值
GMT+8, 2026-5-23 08:32 , Processed in 0.032268 second(s), 20 queries .
