查看: 1367|回复: 0
【FPGA加速大数据】【多岗位诚聘】
ddr 发表于 2015-4-7 14:40:21 | 显示全部楼层 |阅读模式
As a startup company providing innovative system-level FPGA synthesis technologies and data center solutions, Falcon Computing Solutions (FCS) is looking for a talented and committed engineers to join our team in Beijing, China. We have openings in both long-term job position and short-term internship. Please e-mail your resume to human_resource@falcon-computing.com for immediate consideration.
Thank you for considering employment at FCS.
We have the following positions:
[FPGA Application Engineer]
Implementing and optimizing the specific applications with FPGAs in the clusters
- Must have these skills
o Strong experience on architecture and micro-architecture design and optimizations
o Strong experience on C/C++ programming on Linux
o MS/PhD or 3+ years of relevant experience on digital logic circuit designs
- Preferred to have any of these skills
o Knowledge on high-level synthesis design flow
o Knowledge on machine learning applications
o Experience on big data infrastructure such as Hadoop and Spark
o Experience on GPU designs
[Runtime Engineer]
Developing runtime system for the accelerators in heterogeneous clusters
o Strong experience on Hadoop and Spark programming
o Strong experience on C/C++/Java programming on Linux
o MS/PhD or 3+ years of relevant experience on cluster computing
o Knowledge on FPGA or GPU designs
o Familiarity with the source code of Hadoop and Spark infrastructure
[Software Engineer]
Source-to-source code transformation for automated architectural optimizations
o Familiarity with C/C++/STL development on Linux
o Familiarity with ROSE/Clang compiler infrastructure
o MS/PhD or 3+ years of relevant experience on compiler frontend and IR optimizations
o Experience on parallel programming models
o Automated loop and data transformation for high-level synthesis
o Strong experience on scripting languages
Salary: 12K-(no limit) + stock option
Opportunity: support to work at headquarter in Los Angeles periodically.
About Falcon Computing Solutions:
Falcon Computing Solutions (FCS), Inc. is a privately held company providing complete compilation and runtime management solutions to enable FPGA-based customized computing for big-data applications in cloud computing. FCS was founded in 2014 leveraging multi-year research program on customizable domain-specific computing (led by Prof. Jason Cong) at UCLA. FCS is headquartered in Los Angeles, California, USA with an R&D center in Beijing, China.
GMT+8, 2026-5-23 15:56 , Processed in 0.031238 second(s), 20 queries .
