查看: 1503|回复: 1
烧写EPCS遇到写保护的问题
lanlingshan 发表于 2015-8-2 16:20:45 | 显示全部楼层 |阅读模式
烧写EPCS的时候提示“Error (209077): Can't erase or program protected sectors in the EPCS device”;查看Quartus的帮助时说:
CAUSE:        You attempted to erase or program the protected sectors of at least one EPCS device in the JTAG chain, but are unable to do so.
ACTION:        You can either deselect devices with protected sectors from the erase or program operation, or enable the Unprotect EPCS devices selected for the erase/program operation option to clear the protection before performing the erase or program operation.
这个可以设置么?我怀疑是EPCS可能是从其他地方拆下来的,之前就有程序在里面,如果FPGA芯片跟之前下载的程序芯片不对的话,就烧不进去了;这个问题是否可以解决呢?
cuijunlang 发表于 2015-8-8 17:01:35 来自手机 | 显示全部楼层
使用super3000刷新一下,然后重新烧写
GMT+8, 2026-5-23 06:06 , Processed in 0.034179 second(s), 20 queries .
