查看: 1544|回复: 1
新手请指教
mickysu300 发表于 2011-3-19 23:09:19 | 显示全部楼层 |阅读模式
刚开始学FPGA,请各位F友多多指教。欢迎各位留言交流经验
 楼主| mickysu300 发表于 2011-3-20 14:35:10 | 显示全部楼层
我编了个小代码,仿真时出现竞争与冒险问题。有何解决办法不?高手一般是如何处理竞争与冒险的
library ieee;
        use ieee.std_logic_1164.all;
entity myFullAdder4 is
        port(a,b:in std_logic_vector(3 downto 0);
                c0:in std_logic;
                c4ut std_logic;
                sut std_logic_vector(3 downto 0));
end myFullAdder4;
architecture behavior of myFullAdder4 is
        signal cc:std_logic_vector(3 downto 0);
        signal ss:std_logic_vector(4 downto 0):="00000";
        cc<=(0=>c0,others=>'0');
        ss<=('0'&a)+('0'&b)+('0'&cc);
        s<=a + b + cc;
        c4<=ss(4);
end behavior;
GMT+8, 2026-5-24 02:44 , Processed in 0.031537 second(s), 20 queries .
