查看: 3529|回复: 9
简单的序列检测器
陈飞龙 发表于 2015-8-5 22:36:57 | 显示全部楼层 |阅读模式
//输入大写字母、小写字母和符号,输出 I Love You! 字符串
module ily(
        input        wire                 clk,   //系统时钟
        input        wire                 rst_n, //复位
        input        wire  [7:0]  lowercase,//小写字母和符号
        input        wire  [7:0]         capital, //大写
        output        reg   [31:0] love   //输出字符串 I Love You!
        reg [3:0] state; //状态寄存器
                if(!rst_n)
                                love  <= 0; //初始化
                                state <= 0; //状态赋初值
                                case(state)
                                 0:begin       //这里的“I”也可以写成I的ascii  love=73
                                        if(capital == "I") //检测到 I 输出,并跳转
                                                        love <= "I";
                                                        state <= 1;
                                                state <= 0; //检测不到 I 一直等待
                                 1:begin
                                        if(lowercase == " ")//检测到空格输出 也可以写成空格的ascii码 love=64
                                                        love <= " ";
                                                        state <= 2;
                                                state <= 1;//检测不到空格 一直等待
                                 2:begin
                                        if(capital == "L")//检测到L输出  love=76
                                                        love <= "L";
                                                        state <= 3;
                                                state <= 2;
                                 3:begin
                                        if(lowercase == "o")//检测到o输出  love=111
                                                        love <= "o";
                                                        state <= 4;
                                                state <= 3;
                                 4:begin
                                        if(lowercase == "v")//检测到v输出  love=118
                                                        love <= "v";
                                                        state <= 5;
                                                state <= 4;
                                 5:begin
                                        if(lowercase == "e")//检测到e输出  love=101
                                                        love <= "e";
                                                        state <= 6;
                                                state <= 5;
                                 6:begin
                                        if(lowercase == " ")//检测到空格输出  love=64
                                                        love <= " ";
                                                        state <= 7;
                                                state <= 6;
                                 7:begin
                                        if(capital == "Y")//检测到Y输出  love=89
                                                        love <= "Y";
                                                        state <= 8;
                                                state <= 7;
                                 8:begin
                                                        love <= "o";
                                                        state <= 9;
                                                state <= 8;
                                 9:begin
                                        if(lowercase == "u")//检测到u输出  love=117
                                                        love <= "u";
                                                        state <= 10;
                                                state <= 9;
                                 10:begin
                                        if(lowercase == "!")//检测到!输出  love=33
                                                        love <= "!";
                                                        state <= 0;
                                                state <= 10;
                                default : state <= 0;
                                endcase
测试代码如下:
`timescale 1ns/1ns  //时间单位是1ns 时间精度是1ns
module ily_tb;
        reg                        clk;
    reg                        rst_n;
    reg         [7:0]        lowercase;
    reg         [7:0]        capital;
    wire [31:0]        love;
        initial begin
                clk   = 1;
                rst_n = 0;
                lowercase = 0;
                capital          = 0;
                #200
                rst_n = 1;
                //随机输出
                /*forever begin
                        #20 lowercase = "a"; capital = "A";
                        #20 lowercase = "o"; capital = "B";
                        #20 lowercase = "c"; capital = "I";
                        #20 lowercase = "v"; capital = "L";
                        #20 lowercase = "!"; capital = "D";
                        #20 lowercase = "a"; capital = "Y";
                        #20 lowercase = "e"; capital = "S";
                        #20 lowercase = " "; capital = "A";
                        #20 lowercase = "u"; capital = "A";
                end*/
                    //有序输出
                /* forever begin
                         #20 capital = "I";
                         #20 capital = "L";
                         #20 capital = "Y";
                 end        */
        /* initial  //通过任务产生随机数
                 forever begin
                         #400                //启动任务
                         locale();  //任务必须写在initial块里启动
         initial
                forever begin
                         #400
                         cap();
         task cap(); //产生大写字母的任务
         integer i;
                         for(i=0;i<200;i=i+1)
                                         @(posedge clk);
                                          capital <= {$random}%i;
         endtask
         task locale(); //产生小写字母的任务
         integer i;
                                         @(posedge clk);
                                          lowercase <= {$random}%i;
         endtask */
        initial begin  //产生随机数
                forever begin
                        #20 lowercase <= {$random}%128;
                end                //产生0-127之间的一个数
        end                        //如果写成 $ramdom%128 会产生一个-127~127之间的数
        initial begin
                forever begin
                        #20 capital <= {$random}%128;
        always #10 clk=~clk;
ily        ily_inst(
        .clk                (clk),
        .rst_n                (rst_n),
        .lowercase        (lowercase),//小写字母和符号
        .capital        (capital), //大写
        .love       (love)
小梅哥 发表于 2015-8-6 08:28:16 | 显示全部楼层
提个建议,关于楼主的注释习惯方面的。端口信号名一定要定义,还有,写代码很重要,但是配套的文档讲解更加重要。希望文档中多多描述,最起码要具备三点,设计目的,设计思路,设计结论。设计目的就是你想实现的效果,设计思路是你针对目的,在设计代码架构时的思路,例如使用状态机、线性序列机,状态机不一定强制要求有状态转移图,但是最起码要有状态介绍。设计结论,个人认为需要包含两点,第一,编译警告是否存在,如果存在且是可以接受的,讲明原因。第二,仿真结果,最起码有1~3张modelsim的仿真结果贴上来,以验证你的设计确实能够实现你想要的效果。
王建飞 发表于 2015-8-6 10:51:14 | 显示全部楼层
提个建议,关于楼主的注释习惯方面的。端口信号名一定要定义,还有,写代码很重要,但是配套的文档讲解更加 ...
小梅哥点评很到位,另外,代码最好不要直接复制粘贴上来,而是需要先在notpad++里面编辑一下,这个你可以参考伟大的小梅哥编写的教程
zhiweiqiang33 发表于 2015-8-6 15:55:18 | 显示全部楼层
评语很新颖 很到位
 楼主| 陈飞龙 发表于 2015-8-6 18:02:55 来自手机 | 显示全部楼层
谢谢几位老师的建议,我以后会努力从这几方面改进的。以后还希望几位老师多多指点。
508482294 发表于 2022-1-1 17:26:13 | 显示全部楼层
简单的序列检测器
大鹏 发表于 2022-1-13 21:15:51 | 显示全部楼层
简单的序列检测器
大鹏 发表于 2022-10-28 14:52:00 | 显示全部楼层
简单的序列检测器
zxopenhl 发表于 2022-11-2 15:16:43 | 显示全部楼层
简单的序列检测器
GMT+8, 2026-5-22 11:56 , Processed in 0.045012 second(s), 21 queries .
