查看: 1173|回复: 0
TimeQuest Example: Basic SDC Example
王建飞 发表于 2015-9-1 14:49:41 | 显示全部楼层 |阅读模式
set_input_delay -clock clk -max 3 [all_inputs]
set_input_delay -clock clk -min 2 [all_inputs]The Synopsys Design Constraint (SDC) format provides a simple and easy method to constrain the simplest to the most complex designs. The following example provides the simplest SDC file content that constrains all clock (ports and pins), input I/O paths, and output I/O paths for a design. You can use the SDC file below as a template for any design. However, each design should contain a customized SDC file that individually constrains all clocks, input ports, and output ports.
# Constrain clock port clk with a 10-ns requirement
create_clock -period 10 [get_ports clk]
# Automatically apply a generate clock on the output of phase-locked loops (PLLs)
# This command can be safely left in the SDC even if no PLLs exist in the design
derive_pll_clocks
# Constrain the input I/O path
# Constrain the output I/O path
set_output_delay -clock clk -max 3 [all_inputs]
set_output_delay -clock clk -min 2 [all_inputs]
Design Examples Disclaimer
These design examples may only be used within Altera Corporation devices and remain the property of Altera. They are being provided on an “as-is” basis and as an accommodation; therefore, all warranties, representations, or guarantees of any kind (whether express, implied, or statutory) including, without limitation, warranties of merchantability, non-infringement, or fitness for a particular purpose, are specifically disclaimed. Altera expressly does not recommend, suggest, or require that these examples be used in combination with any other product not provided by Altera
GMT+8, 2026-5-23 06:08 , Processed in 0.030579 second(s), 20 queries .
