查看: 1166|回复: 0
TimeQuest Example: Constraining Generated Clocks
王建飞 发表于 2015-9-1 15:45:38 | 显示全部楼层 |阅读模式
With the Synopsys Design Constraint (SDC) command create_generated_clock, you can create arbitrary numbers and depths of generated clocks. This is useful in the following scenarios. See Figures 1 and 2.
Figure 1 shows a simple circuit where a generated clock is required at the output of register div2reg.
The SDC commands below constrain the clocks in the above circuit.
#Constrain the base clock
create_clock -add -period 10.000 \
-waveform { 0.000 5.000 } \
-name clock_name \
[get_ports clock]
#Constrain the divide by 2 register clock
create_generated_clock -add -source clock \
-name div2clock \
-divide_by 2 \
-master_clock clock_name \
[get_pins div2reg|regout]
Download example circuit create_generated_clock_ex1.qar.
The use of this design is governed by, and subject to, the terms and conditions of the Altera Hardware Reference Design License Agreement.
Figure 2 shows a simple circuit where a generated clock is required at the output of register div2reg.
-name clock_name \
[get_ports clock]
#Constrain the output clock clock
create_generated_clock -add -source PLL_inst|inclk[0] \
-name PLL_inst|clk[1] \
-multiply_by 2 \
[get_pins PLL_inst|clk[1]]
Download example circuit create_generated_clock_pll.qar.
GMT+8, 2026-5-23 06:08 , Processed in 0.032178 second(s), 21 queries .
