查看: 1081|回复: 0
TimeQuest Example: Reporting Point-to-Point Delays
王建飞 发表于 2015-9-2 09:38:50 | 显示全部楼层 |阅读模式
With the TimeQuest command report_path, you can generate delay reports from any arbitrary node to any arbitrary node in the design. This command is useful for debugging and determining the data or clock delay between any two nodes. The report_path command reports only delays between two keeper nodes, i.e. ports, registers, etc. The following example shows the command to report the delay between pin A and pin B.
report_path -from [get_pins A] –to [get_pins B] –panel_name “My Delays”
The use of this design is governed by, and subject to, the terms and conditions of the Altera® Hardware Reference Design License Agreement.
GMT+8, 2026-5-23 06:06 , Processed in 0.031493 second(s), 20 queries .
