查看: 1174|回复: 0
TimeQuest Example: Reporting Unconstrained Paths
王建飞 发表于 2015-9-2 09:39:48 | 显示全部楼层 |阅读模式
With the TimeQuest command report_ucp, you can generate a report that details all unconstrained paths in your design. Unconstrained paths are paths without any timing constraints specified to them, i.e. set_input_delay, create_clock, etc. The report details the type of unconstrained paths: clocks, input ports, outputs ports. Altera recommends that all paths and ports be constrained to achieve optimal placement and fitting results. The following example shows the command to generate an unconstrained path report.
report_ucp -summary
The use of this design is governed by, and subject to, the terms and conditions of the Altera® Hardware Reference Design License Agreement.
GMT+8, 2026-5-23 05:13 , Processed in 0.030807 second(s), 20 queries .
