查看: 1107|回复: 0
TimeQuest Example: Reporting Net Timing
王建飞 发表于 2015-9-5 13:33:43 | 显示全部楼层 |阅读模式
With the TimeQuest command report_net_timing, you can generate a report that details the net delays for specific nets or all nets in your design. A net corresponds to a cell’s output pin.
#Report net timing for an output pin of a register
report_net_timing [get_nets *reg*]
#Report net timing for the top 10 nets
report_net_timing –nworst_delay 10
The use of this design is governed by, and subject to, the terms and conditions of the Altera® Hardware Reference Design License Agreement.
GMT+8, 2026-5-23 06:04 , Processed in 0.035012 second(s), 19 queries .
