查看: 2098|回复: 0
TimeQuest Example: Failing Clocks Summary Report
王建飞 发表于 2015-9-5 13:34:33 | 显示全部楼层 |阅读模式
The script on this page performs setup, hold, recovery, and removal timing analysis on all clocks in your design at all its supported operating conditions. The script creates a table that lists information about all analyses that failed timing. The script writes the table to a file called <revision>.failing_clock_domains. If no analyses failed, the script writes a message to the file that no analyses failed.
You can use the script to get a quick, simple overview of failing timing analysis results for a design. If you save the script in a file called failing_clock_domains.tcl, use the following command to run it.
quartus_sta --report_script=failing_clock_domains.tcl <project name> [-c <revision name>]
Here is an example of the table the script generates if any analyses fail timing. The table includes the worst-case slack, the total negative slack (TNS), the name of the clock, the operating condition in which the failure occurred, and the type of analysis that failed.
Clock domains failing timing
; Slack  ; End Point TNS ; Clock      ; Operating conditions  ; Timing analysis ;
; -0.113 ; -0.321        ; IF_RXCLK   ; Slow 1100mV 85C Model ; Setup           ;
; -0.098 ; -0.223        ; core_clk   ; Fast 1100mV 0C Model  ; Hold            ;
Copy and paste the following Tcl code and save it in a file to use the script.
# Report whether a design has clock domains with negative slack.
# If there are clock domains with negative slack, put that information into
# a table and write it out to a file.
# Change the filename here if appropriate
set output_file_name [get_current_revision].failing_clock_domains
package require struct::matrix
package require report
# Create a matrix to hold information about the failing paths
set failing_paths_matrix [::struct::matrix];
$failing_paths_matrix add columns 5
# Analysis has to be performed for all operating conditions
set all_operating_conditions_col [get_available_operating_conditions]
# Perform these types of analysis for each clock domain
set analysis_list [list "setup" "hold" "recovery" "removal"]
# Walk through all operating conditions
foreach_in_collection operating_conditions_obj $all_operating_conditions_col {
# Set the operating condition, update the timing netlist
set_operating_conditions $operating_conditions_obj
update_timing_netlist
# Get the English-text name of the operating conditions
set operating_conditions_display_name \
[get_operating_conditions_info -display_name $operating_conditions_obj]
# Do every type of analysis
foreach analysis_type $analysis_list {
# Get the name of the analysis type if we have to print it
set analysis_display_name [string totitle $analysis_type]
# Get information about all the clock domains
set clock_domain_info_list [get_clock_domain_info -${analysis_type}]
# Walk through all the clock domains and pull out any that have
# negative slack
foreach domain_info $clock_domain_info_list {
# The domain_info has the clock name, its slack, and its TNS.
# Extract those.
foreach { clock_name slack endpoint_tns edge_tns } $domain_info \
{ break }
# If the slack is negative, put together a row of information to
# report in the table
if { 0 > $slack } {
$failing_paths_matrix add row \
[list $slack $endpoint_tns $clock_name \
$operating_conditions_display_name $analysis_display_name]
# Finished going through all the clock domains for a particular
# timing analysis (setup, hold, etc.)
# Finished going through all the analysis types for a particular operating
# condition
# Finished going through all the operating conditions
# Prepare to write out a file with the results summary
# If there are any rows in the matrix, there are paths that are failing timing.
# We have to print out the table with that information. If there are no
# rows in the table, no paths fail timing, so write out a success message
if { 0 == [$failing_paths_matrix rows] } {
# Print out a quick message
post_message "There are no clock domains failing timing"
# If there is an error opening the file, print a message saying
# that. Otherwise, say there are no domains failing timing
if { [catch { open $output_file_name w } fh] } {
post_message -type error "Couldn't open file: $fh"
} else {
puts $fh "There are no clock domains failing timing"
catch { close $fh }
} else {
# Sort the matrix rows so the worst slack is first
$failing_paths_matrix sort rows -increasing 0
# Put in a header row
$failing_paths_matrix insert row 0 \
[list "Slack" "End Point TNS" "Clock" \
"Operating conditions" "Timing analysis" ]
# We need a style defined to print out the table of results
catch { ::report::rmstyle basicrpt }
::report::defstyle basicrpt {{cap_rows 1}} {
data set [split "[string repeat " " [columns]];"]
top set [split "[string repeat "+ - " [columns]]+"]
bottom set [top get]
topcapsep set [top get]
topdata set [data get]
top enable
topcapsep enable
bottom enable
tcaption $cap_rows }
# Create the report, set the columns to have one space of padding, and
# print out the matrix with the specified format
catch { r destroy }
::report::report r 5 style basicrpt
for { set col 0 } { $col < [r columns]} { incr col } {
r pad $col both " "
post_message "Clock domains failing timing\n[r printmatrix $failing_paths_matrix]"
# Save the report to a file
} else {
puts $fh "Clock domains failing timing"
r printmatrix2channel $failing_paths_matrix $fh
catch { close $fh }
GMT+8, 2026-5-23 04:21 , Processed in 0.036223 second(s), 20 queries .
