查看: 1930|回复: 0
TimeQuest GUI Special Features
王建飞 发表于 2015-9-5 14:19:03 | 显示全部楼层 |阅读模式
The TimeQuest analyzer provides an intuitive and easy-to-use graphic user interface (GUI) that allows you to efficiently constrain and analyze your designs (see Figure 1).
The TimeQuest GUI includes the following panes and features:
Panes
View pane
Tasks pane
Console pane
Report pane
Features
Constraints Menu
Name Finder
Figure 1. The TimeQuest Analyzer GUI
View Pane
The View pane is the main viewing area for the timing analysis results. You can use the View pane to view summary reports, custom reports, or histograms. Figure 2 shows the View pane after you select the Summary (Setup) report from the Report pane.
Figure 2. Summary (Setup) Report
View Pane: Splitting
For the proper analysis of timing results, comparison of multiple reports is extremely important. To facilitate multiple report viewing, the View pane supports window splitting. Window splitting divides the View pane into multiple windows, allowing you to view different reports side-by-side.
You can split the View pane into multiple windows using the split icon located in the upper right hand corner of the View pane. Drag the icon in different directions to generate additional window views in the View pane. For example, if you drag the split icon down, the View pane creates a new window above the current window (See Figure 3).
Figure 3. Splitting the View Pane Horizontally
If you drag the split icon to the left, the View pane creates a new window to the right of the current window (see Figure 4).
Figure 4. Splitting the View Pane to the Left
If you drag the split icon diagonally, the View pane creates three new windows in the View pane (see Figure 5).
Figure 5. Splitting the View Pane Diagonally
Drag the split icon downward to create a new window directly below the current window.
View Pane: Removing Split Windows
You can remove windows that you create in the View pane using the split icon by dragging the border of the window over the window you wish to remove.
Figure 6. Removing Split Windows
Tasks Pane
Use the Tasks pane to access common commands such as netlist setup report generation.
Two common commands are located in the Tasks pane: Open Project and Write SDC File. The other commands are contained in the following folders:
Netlist Setup
Reports
Macros
Note: Each command in the Tasks pane has an equivalent tool command language (Tcl) command that is displayed in the Console pane when the command runs.
To open a project in the TimeQuest analyzer, double-click the Open Project task. If you launch the TimeQuest analyzer from the Quartus II software GUI, the project opens automatically.
You can add or remove constraints from the timing netlist after the TimeQuest analyzer reads the initial Synopsys Design Constraints (SDC) file. After the file is read, the initial SDC file becomes outdated compared to the constraints in the TimeQuest analyzer. Use the Write SDC File command to generate an SDC file that is up-to-date and reflects the current state of constraints in the TimeQuest analyzer.
Netlist Setup Folder
The Netlist Setup folder contains tasks that are used to set up the timing netlist for timing analysis. The three tasks located in this folder are listed in Table 1.
Table 1. Netlist Setup Folder Commands
Notes:
Always create a timing netlist before you perform static timing analysis with the TimeQuest timing analyzer.
Use the read_sdc command to read an SDC file that is not associated with the current revision of the design.
Reports Folder
The Reports folder contains commands to generate timing summary reports of the static timing analysis results. The nine commands located in this folder are summarized in Table 2.
Table 2. Reports Folder Commands
Macros Folder
The Macros folder contains commands that perform custom tasks available in the TimeQuest analyzer utility package. These commands are listed in Table 3.
Table 3. Macros Folder Commands
Console Pane
The Console pane is both a message center for the TimeQuest analyzer, and an interactive Tcl. It has two tabs: the Console tab and the History tab. All messages (such as info and warning messages) appear in this pane.
The Console tab allows you to enter and run SDC and Tcl commands. It also shows the Tcl equivalent of all commands that you run in the Tasks pane.
The History tab records all the SDC and Tcl commands that have run.
Note: To run the commands located in the History tab after the timing netlist has been updated, right-click the command, and click Re-run.
You can copy Tcl commands from the Console and History tabs to easily generate Tcl scripts to perform timing analysis.
Report Pane
Use the Report pane to access all reports generated from the Tasks pane, and any custom report commands. When you select a report in the Report pane, it is shown in the active window in the View pane.
Note: If a report is out of date with respect to the current constraints, a “?” icon is shown next to the report.
Constraints Menu
You can use the Constraints menu to access commonly used constraints, exceptions, and commands. The following commands are available on the Constraints menu:
Create Clock
Create Generated Clock
Set Clock Latency
Set Clock Uncertainty
Remove Clock
For example, you can use the Create Clock dialog box to create clocks in your design. Figure 7 shows the Create Clock dialog box.
Figure 7. Create Clock Dialog Box
The following commands specify timing exceptions, and are also available on the Constraints menu:
Set False Path
Set Multicycle Path
Set Maximum Delay
Set Minimum Delay
All the dialog boxes used to specify timing constraints or exceptions from commands have an SDC command field. This field contains the SDC file constraint that is run when you click OK.
Note: All commands and constraints created in the TimeQuest user interface are echoed in the Console pane.
The constraints specified with Constraints menu commands are not saved to the current SDC file automatically. You must run the Write SDC File command to save your constraints. The following SDC commands are available on the Constraints menu in the TimeQuest analyzer:
Generate SDC File from QSF
Read SDC File
Write SDC File
The Generate SDC File from QSF command runs a Tcl script that converts the Classic Timing Analyzer constraints in a QSF file to an SDC file for the TimeQuest analyzer. The file <current revision>.sdc is created by this command.
Name Finder
Use the Name Finder dialog box to select the target for any constraints or exceptions in the TimeQuest analyzer GUI. The Name Finder allows you to specify collections, filters, and filter options. The Collections field in the Name Finder dialog box allows you to specify the type of name to select. To select the type, in the Collection list, select the desired collection application program interface (API), including:
get_cells
get_clocks
get_keepers
get_nets
get_nodes
get_pins
get_ports
get_registers
Note: For more information on the various collection APIs, refer to Collections.
The Filter field allows you to filter names based on your own criteria including wildcards characters. You can further refine your results using the following filter options:
Case-insensitive
Hierarchical
Compatibility mode
The Name Finder dialog box also provides an SDC command field that displays the currently selected name search command. You can copy the value from this field and use it for other constraint target fields. The Name Finder dialog box is shown in Figure 8.
Figure 8. Name Finder Dialog Box
GMT+8, 2026-5-23 06:06 , Processed in 0.033110 second(s), 21 queries .
