查看: 1461|回复: 0
新手请教!!!
zilong19800228 发表于 2011-3-31 19:49:13 | 显示全部楼层 |阅读模式
用XC2V1000芯片(256管脚)实现了一个逻辑,生成烧写文件的时候出现以下错误:
The current designer locked placement of the IOBs A and B make this design unroutable due to a physical routing limition。This device has
a share resource connecting the ICLK and OTCLK pins on pairs of IOBs 。This restriction means that these pairs of pins must be driven by the same signal or one of the signals will be unroutable 。
我感觉大概意思是A和B这两个信号的位置被锁定,所以不能完成布线,这两个信号必须是同一个信号源或者有一个信号不定义。
但是我使了一下将B信号只过一个与门输出没有问题,只要再连接一个逻辑就会报错包括用chipscorp引出测试点都不可以,请问这是什么问题,怎么解决?谢谢,谢谢!!!!
GMT+8, 2026-5-24 02:44 , Processed in 0.031738 second(s), 20 queries .
