查看: 2817|回复: 1
请问哪位大侠有uedit32 程序关键字显高亮 ?
IPO 发表于 2011-4-1 08:32:46 | 显示全部楼层 |阅读模式
njithjw 发表于 2011-4-1 20:47:26 | 显示全部楼层
/L14"Verilog 1364-2001" Line Comment = // Block Comment On = /* Block Comment Off = */ String Chars = " File Extensions = V VL VMD
/Colors = 0,8421376,8421376,8421504,255,
/Colors Back = 16777215,16777215,16777215,16777215,16777215,
/Colors Auto Back = 1,1,1,1,1,
/Font Style = 0,0,0,0,0,
/Delimiters = ~!@%^&*()-+=|\/{}[]:;"<> ,
/Function String = "%[ ^t]++^(config[ ^t^p]+[a-zA-Z0-9_]+^)"
/Function String 1 = "%[ ^t]++^(module[ ^t^p]+[a-zA-Z0-9_]+^)[ ^t^p]++[(;#]"
/Function String 2 = "%[ ^t]++^(task[ ^t^p]+[~(;]+^)[ ^t^p]++[(;#]"
/Function String 3 = "%[ ^t]++^(function[ ^t^p]+[~(;]+^)[ ^t^p]++[(;#]"
/Function String 4 = "%[ ^t]++^(primitive[ ^t^p]+[~(;]+^)[ ^t^p]++[(;#]"
/Function String 5 = "begin[ ^t^p]++^(:[ ^t^p]++[a-zA-Z0-9_]+^)"
/Indent Strings = "begin" "case" "fork" "specify" "table" "config"
/Unindent Strings = "end" "endcase" "join" "endspecify" "endtable" "endconfig"
/Open Fold Strings = "module" "task" "function" "generate" "primitive" "begin" "case" "fork" "specify" "table" "config" "`ifdef"
/Close Fold Strings = "endmodule" "endtask" "endfunction" "endgenerate" "endprimitive" "end" "endcase" "join" "endspecify" "endtable" "endconfig" "`endif"
/C1"Keywords" Colors = 16711680 Colors Back = 16777215 Colors Auto Back = 1 Font Style = 0
always and assign automatic
begin buf bufif0 bufif1
case casex casez cell cmos config
deassign default defparam design disable
edge else end endcase endconfig endmodule endfunction endgenerate endprimitive endspecify endtable endtask event
for force forever fork function
generate genvar
highz0 highz1
if ifnone initial inout input instance integer
join
large liblist library localparam
macromodule medium module
nand negedge nmos none nor noshowcancelled not notif0 notif1
or output
parameter pulsestyle_onevent pulsestyle_ondetect pmos posedge primitive pull0 pull1 pullup pulldown
real realtime reg release repeat rcmos rnmos rpmos rtran rtranif0 rtanif1
scalared showcancelled signed small specify specparam strength strong0 strong1 supply0 supply1
table task time tran tranif0 tranif1 tri tri1 tri0 triand trior trireg
use
vectored
wait wand weak0 weak1 while wire wor
xnor xor
/C2"System" Colors = 255 Colors Back = 16777215 Colors Auto Back = 1 Font Style = 0
** 'b 'B 'o 'O 'd 'D 'h 'H 'sb 'sB 'so 'sO 'sd 'sD 'sh 'sH 'Sb 'SB 'So 'SO 'Sd 'SD 'Sh 'SH
$async$and$array $async$and$plane $async$nand$array $async$nand$plane $async$nor$array $async$nor$plane $async$or$array $async$or$plane
$bitstoreal
$countdrivers
$display $displayb $displayh $displayo
$dist_chi_square $dist_erlang $dist_exponential $dist_normal $dist_poisson $dist_t $dist_uniform
$dumpall $dumpfile $dumpflush $dumplimit $dumpoff $dumpon $dumpportsall $dumpportsflush $dumpportslimit $dumpportsoff $dumpportson $dumpvars
$fclose $fdisplayh $fdisplay $fdisplayf $fdisplayb $ferror $fflush $fgetc $fgets $finish $fmonitorb $fmonitor $fmonitorf $fmonitorh $fopen $fread $fscanf $fseek $fsscanf $fstrobe $fstrobebb $fstrobef $fstrobeh $ftel $fullskew $fwriteb $fwritef $fwriteh $fwrite
$getpattern
$history $hold
$incsave $input $itor
$key
$list $log
$monitorb $monitorh $monitoroff $monitoron $monitor $monitoro
$nochange $nokey $nolog
$period $printtimescale
$q_add $q_exam $q_full $q_initialize $q_remove
$random $readmemb $readmemh $realtime $realtobits $recovery $recrem $removal $reset_count $reset $reset_value $restart $rewind $rtoi
$save $scale $scope $sdf_annotate $setup $setuphold $sformat $showscopes $showvariables $showvars $signed $skew $sreadmemb $sreadmemh $stime $stop $strobeb $strobe $strobeh $strobeo $swriteb $swriteh $swriteo $swrite $sync$and$array $sync$and$plane $sync$nand$array $sync$nand$plane $sync$nor$array $sync$nor$plane $sync$or$array $sync$or$plane
$test$plusargs $time $timeformat $timeskew
$ungetc $unsigned
$value$plusargs
$width $writeb $writeh $write $writeo
/C3"Operators" Colors = 33023 Colors Back = 16777215 Colors Auto Back = 1 Font Style = 0
/C4"Directives" Colors = 32768 Colors Back = 16777215 Colors Auto Back = 1 Font Style = 0
`accelerate `autoexepand_vectornets
`celldefine
`default_nettype `define `default_decay_time `default_trireg_strength `delay_mode_distributed `delay_mode_path `delay_mode_unit `delay_mode_zero
`else `elsif `endcelldefine `endif `endprotect `endprotected `expand_vectornets
`file
`ifdef `ifndef `include
`line
`noaccelerate `noexpand_vectornets `noremove_gatenames `noremove_netnames `nounconnected_drive
`protect `protected
`remove_gatenames `remove_netnames `resetall
`timescale
`unconnected_drive `undef `uselib
/C5"DelaysParametersEscaped" Colors = 4210816 Colors Back = 16777215 Colors Auto Back = 1 Font Style = 0
GMT+8, 2026-5-24 01:26 , Processed in 0.032608 second(s), 20 queries .
