查看: 1339|回复: 0
警告-- Removed fan-out from the always-disabled I/O buffer 是什么意思
hxing 发表于 2015-9-26 22:36:13 | 显示全部楼层 |阅读模式
  请问下面这个 警告是什么意思:
        Warning (13028): Removed fan-out from the always-disabled I/O buffer "DS18B20_Init:u2|DS18B20_Check:u2|check_IO" to the node "DQ_IO"
谢谢!
GMT+8, 2026-5-23 04:22 , Processed in 0.042261 second(s), 20 queries .
