查看: 931|回复: 0
Design Assistant Rules Dialog Box
Esmiamor 发表于 2016-1-20 21:57:41 | 显示全部楼层 |阅读模式
You open this dialog box by clicking Browse (...) in the Value box of the Assignment Editor for a node with the Enable Design Assistant Rule or Disable Design Assistant Rule assignment.
This dialog box allows you to apply design assistant rules to the specified node. Select the Design Assistant rule or rules you want to assign in the Rules list and assign it with the > button. The rule you have selected should appear in the Selected rules list. You can assign all the Design Assistant rules with the >> button, clear individual rules with the < button, or clear all assigned rules with the << button.
Contact Altera | Legal Notice
Copyright&#169; 2015 Altera Corporation. All rights reserved. ALTERA, ARRIA, CYCLONE, HARDCOPY, MAX, MEGACORE, NIOS, QUARTUS, STRATIX, and all other brands, unless noted otherwise, and/or trademarks of Altera Corporation in the U.S. and other countries.
GMT+8, 2026-5-24 21:38 , Processed in 0.051101 second(s), 20 queries .
