查看: 860|回复: 0
Add JTAG ID Dialog Box
Esmiamor 发表于 2016-1-20 21:58:40 | 显示全部楼层 |阅读模式
You open this dialog box by clicking Add JTAG ID in the New Device or Edit Device dialog box.
Allows you to specify a configuration device JTAG ID and JTAG ID mask.
Configuration Device JTAG ID (32-bit hexadecimal)—Allows you to specify the 32-bit hexadecimal number for the configuration device. The JTAG ID includes such information as the manufacturer's ID number, the part number, and the device identity.
Configuration Device JTAG ID Mask (32-bit hexadecimal)—Allows you, in conjunction with the Configuration Device JTAG ID (32-bit hexadecimal) value, to specify which bits should be checked in the JTAG ID. Bits set to 1 in the JTAG ID mask are checked in the JTAG ID; bits set to O in the JTAG ID mask are ignored in the JTAG ID. For example, to check only the last eight bits in a JTAG ID, set the JTAG ID mask to 0x000000FF.
Contact Altera | Legal Notice
Copyright© 2015 Altera Corporation. All rights reserved. ALTERA, ARRIA, CYCLONE, HARDCOPY, MAX, MEGACORE, NIOS, QUARTUS, STRATIX, and all other brands, unless noted otherwise, and/or trademarks of Altera Corporation in the U.S. and other countries.
GMT+8, 2026-5-24 21:35 , Processed in 0.043184 second(s), 20 queries .
