查看: 1047|回复: 0
Export User-Defined Device Dialog Box
Esmiamor 发表于 2016-1-20 21:59:01 | 显示全部楼层 |阅读模式
You open this dialog box by clicking Export in the Select New Device dialog box.
Allows you to export user-defined devices in a Quartus Prime Standard Edition User-Defined Device File (.qud) Definition. The Quartus User-Defined Device File contains all user-defined devices listed under the Device name list when you select User Defined in the Device family list.
Contact Altera | Legal Notice
Copyright© 2015 Altera Corporation. All rights reserved. ALTERA, ARRIA, CYCLONE, HARDCOPY, MAX, MEGACORE, NIOS, QUARTUS, STRATIX, and all other brands, unless noted otherwise, and/or trademarks of Altera Corporation in the U.S. and other countries.
GMT+8, 2026-5-24 21:29 , Processed in 0.030501 second(s), 20 queries .
