查看: 1172|回复: 0
Import User Devices Dialog Box
Esmiamor 发表于 2016-1-20 21:59:50 | 显示全部楼层 |阅读模式
You open this dialog box by clicking Import in the Select Devices dialog box.
Allows you to import user-defined devices from a Quartus Prime Standard Edition User-Defined Device File (.qud) Definition. User-defined devices imported from a Quartus User-Defined Device File are listed under the Device name list when you select User Defined in the Device family list.
Also allows you to import a Boundary-Scan Description Language File (.bsd) DefinitionBoundary-Scan Description File(.bsd).
Contact Altera | Legal Notice
Copyright© 2015 Altera Corporation. All rights reserved. ALTERA, ARRIA, CYCLONE, HARDCOPY, MAX, MEGACORE, NIOS, QUARTUS, STRATIX, and all other brands, unless noted otherwise, and/or trademarks of Altera Corporation in the U.S. and other countries.
GMT+8, 2026-5-24 20:48 , Processed in 0.034719 second(s), 20 queries .
