查看: 3094|回复: 2
帮忙看一下这两个warning有没有影响
老怪甲 该用户已被删除
老怪甲 发表于 2010-4-16 20:05:50 | 显示全部楼层 |阅读模式
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1000 = PERIOD:PERIOD_sysq<12>.Q:0.000 nS because of one of the following: (a) a signal name was not found; (b) a signal was removed or renamed due to optimization; (c) there is no path between the FROM node and TO node in the TIMESPEC.
WARNING:Cpld:310 - Cannot apply TIMESPEC TS1018 = PERIOD:PERIOD_iow:0.000 nS because of one of the following: (a) a signal name was not found; (b) a signal was removed or renamed due to optimization; (c) there is no path between the FROM node and TO node in the TIMESPEC.
这是用ISE 11.1  Fit之后出现的警告,不知道是不是说我的布局有问题,或者说没有影响?
老怪甲 该用户已被删除
 楼主| 老怪甲 发表于 2010-4-16 20:06:11 | 显示全部楼层
这两个warning没有影响,应该是ISE在优化的时候将没有用的信号去掉了,只要符合你的设计目标就可以了
Sunlife 发表于 2015-4-8 14:25:27 | 显示全部楼层
GMT+8, 2026-5-23 11:00 , Processed in 0.033127 second(s), 21 queries .
