查看: 11116|回复: 11
单独按键消抖
奋斗的小孩 发表于 2016-7-17 10:50:46 | 显示全部楼层 |阅读模式
module key_filter(clk, rst_n, key_n, click_n);
        parameter MASK_TIME = 100;
        input clk;
        input rst_n;
        input key_n;
        output reg click_n;
        localparam s0 = 1'b0;
        localparam s1 = 1'b1;
        reg temp;
        reg [31:0] count;
        reg state;
        always @ (posedge clk, negedge rst_n)
                if (!rst_n)
                                count <= 0;
                                click_n <= 1;
                                temp <= 1;
                                state <= s0;
                        case (state)
                                s0        :        if (key_n == temp)
                                                        state <= s0;
        temp <= key_n;
        state <= s1;
                                s1        :        if (key_n == temp)
                                                        if (count < MASK_TIME)
        count <= count + 1;
        state <= s1;
        click_n <= temp;
        count <= 0;
        state <= s0;
        count <= 0;
        temp <= key_n;
        state <= s1;
                        endcase
 楼主| 奋斗的小孩 发表于 2016-7-17 10:51:02 | 显示全部楼层
奋斗的小孩
zxopen08 发表于 2016-8-13 17:15:26 | 显示全部楼层
单独按键消抖
Sure 发表于 2016-8-14 16:11:40 | 显示全部楼层
               感谢分享
辉煌 发表于 2016-8-21 11:40:11 | 显示全部楼层
感谢分享
Esmiamor 发表于 2016-8-21 16:52:34 | 显示全部楼层
             支持。
辉煌 发表于 2016-8-30 09:27:24 | 显示全部楼层
单独按键消抖
4798345 发表于 2017-3-11 09:13:57 | 显示全部楼层
66666666666666666666666666
星坠天际 发表于 2017-3-11 11:41:58 | 显示全部楼层
单独按键消抖
fpga_feixiang 发表于 2023-11-21 14:19:22 | 显示全部楼层
6
GMT+8, 2026-5-22 07:22 , Processed in 0.033506 second(s), 20 queries .
