查看: 1717|回复: 3
从e2prom读取数据 编写思路
打铁小肥罗 发表于 2016-8-4 19:27:13 | 显示全部楼层 |阅读模式
由上图可以写出各个状态
1.Start
在scl高电平时,sda由高拉低
2.写入控制字
在scl低电平时写入八位控制字
3.接收ack
在scl高电平时,如果接收的ack为低电平,进行下一个状态,如果接收的ack为高电平,返回上一级
4.写入高位地址
在scl低电平时写入
5.接收ack
同3
6..写入地位地址
在scl低电平写入
7.接收ack
同3
8.将sda拉高
因为下一步要进行start,所以要保证sda,scl都为高电平
9.Start
同1
10.发送控制字
同2
11.接收ack
同3
12.读数据
此时要保证scl高电平,flag为0(flag为sda三态门开关
sda=(flag==1)?Data_out:1’bz)
13.NO ack
FPGA向e2prom传输信号,scl为低电平,flag=1,data_out=1;
14.将sda拉低
以为下一步要进行stop,所以先将sda置为低电平
15.Stop
在scl=1的时候将事先置为低电平的sda拉高,stop。
附图2为仿真波形
程序如下
module iic_rd(clk,rst_n,scl,sda,q);
        input clk;
        input rst_n;
        output reg scl;
        output reg [7:0]q;
        inout sda;
        reg inclk;
        reg [31:0]count;
        reg [31:0]count3;
        reg [7:0]temp;
        reg [15:0]addr;
        reg [7:0]data_out;
        reg [3:0]state;
        reg flag;
        reg [7:0]data;
        always@(posedge clk or negedge rst_n)
                        if(rst_n==0)
                                        inclk<=0;
                                        count<=0;
                                        if(count<62)
                                                        count<=count+1;
                                                        inclk<=~inclk;
        always@(negedge inclk or negedge rst_n)
                        if(rst_n==0)
                                        scl<=1;
                                        if(state<14)
                                                        scl=~scl;
                                                        scl<=1;
        assign sda=(flag==1)? data_out:1'bz;
        always@(posedge inclk or negedge rst_n)
                        if(rst_n==0)
                                        flag<=1;
                                        data_out<=1;
                                        count3<=0;
                                        state<=0;
                                        temp<=8'b1010_0000;
                                        addr<=16'b0000_0000_0000_0000;
                                        q<=8'b0000_0000;
                                        case(state)
                                                        0:                                                //start
        if(scl==1)
        flag<=1;
        data_out<=0;
        state<=1;
                                                        1:                                                //control
        if(scl==0 && count3<8)
        flag<=1;
        data_out<=temp[7];
        count3<=count3+1;
        temp<={temp[6:0],temp[7]};
        state<=1;
        else if(scl==0 && count3==8)
        count3<=0;
        state<=2;
        flag<=0;
                                                        2:                                                //ack
        if(scl==1)
        //begin
        //if(sda==0)
        state<=3;
        data_out<=0;
        //end
        //else
        //begin
        //state<=1;
        //end
                                                        3:                                                //high addr
        flag<=1;
        data_out<=addr[15];
        count3<=count3+1;
        addr<={addr[14:0],addr[15]};
        state<=3;
        count3<=0;
        state<=4;
        flag<=0;
                                                        4:                                                //ack
        if(scl==1)
        //begin
        //if(sda==0)
        state<=5;
        data_out<=0;
        //end
        //else
        //begin
        //state<=3;
        //end
                                                        5:                                                //low addr
        flag<=1;
        data_out<=addr[15];
        count3<=count3+1;
        state<=5;
        count3<=0;
        state<=6;
        flag<=0;
                                                        6:                                                //ack
        if(scl==1)
        //begin
        //if(sda==0)
        state<=7;
        data_out<=0;
        //end
        //else
        //begin
        //state<=5;
        //end
                                                        7:                                                //将sda拉高
        if(scl==0)
        flag<=1;
        data_out<=1;
        state<=8;
                                                        8:                                                //start
        if(scl==1)
        flag<=1;
        data_out<=0;
        state<=9;
        temp<=8'b1010_0001;
                                                        9:                                                //control
        flag<=1;
        data_out<=temp[7];
        count3<=count3+1;
        state<=9;
        count3<=0;
        state<=10;
        flag<=0;
                                                        10:                                        //ack
        if(scl==1)
        //begin
        //if(sda==0)
        state<=11;
        data_out<=0;
        //end
        //else
        //begin
        //state<=9;
        //end
                                                        11:                                        //data
        if(scl==1 && count3<8)
        flag<=0;
        data<=sda;
        count3<=count3+1;
        data<={data[6:0],sda};
        state<=11;
        else if(scl==1 && count3==8)
        count3<=0;
        state<=12;
        flag<=1;
        q<=data;
                                                        12:                                        //no ack
        if(scl==0)
        flag<=1;
        data_out<=1;
        state<=13;
                                                        13:                                        //sda拉低
        if(scl==0)
        flag<=1;
        data_out<=0;
        state<=14;
                                                        14:                                        //stop
        if(scl==1)
        flag<=1;
        data_out<=1;
                                                        default:                                //default
        state<=0;
                                        endcase
芙蓉王 发表于 2016-8-5 17:06:06 | 显示全部楼层
                           非常棒,求继续
zhiweiqiang33 发表于 2016-8-18 17:03:12 | 显示全部楼层
继续加油 努力学习中
GMT+8, 2026-5-24 21:35 , Processed in 0.033385 second(s), 21 queries .
