楼主: lcytms
FPGA初级课程第十一讲 键盘矩阵
 楼主| lcytms 发表于 2016-11-11 17:05:17 | 显示全部楼层
进行分析综合检查。
进行仿真设置。
查看仿真结果。
每次按键按下之后,数据位data和标志位flag都有对应数字的输出。
仿真功能正确。
 楼主| lcytms 发表于 2016-11-11 17:06:00 | 显示全部楼层
向工程文件夹添加第四讲的数码管模块seg7.v。
module seg7 (clk, rst_n, data, sel, seg);
        input clk, rst_n;
        input [23:0] data;
        output reg [2:0] sel;
        output reg [7:0] seg;
        reg clk_1k;
        parameter T1ms = 25_000;                //half_width
        reg [19:0] count;
                        if (!rst_n)
                                        count <= 0;
                                        clk_1k <= 1;
                                        if (count < T1ms - 1)
                                                        count <= count + 20'b1;
                                                        count <= 0;
                                                        clk_1k <= ~clk_1k;
        reg [2:0] state;
        reg [3:0] data_temp;
        always @ (posedge clk_1k or negedge rst_n)
                        if (!rst_n)
                                        sel <= 3'b000;
                                        state <= 0;
                                        case (state)
                                        0        :        begin
        sel <= 3'b000;
        data_temp <= data[23:20];
        state <= 1;
                                        1        :        begin
        sel <= 3'b001;
        data_temp <= data[19:16];
        state <= 2;
                                        2        :        begin
        sel <= 3'b010;
        data_temp <= data[15:12];
        state <= 3;
                                        3        :        begin
        sel <= 3'b011;
        data_temp <= data[11:8];
        state <= 4;
                                        4        :        begin
        sel <= 3'b100;
        data_temp <= data[7:4];
        state <= 5;
                                        5        :        begin
        sel <= 3'b101;
        data_temp <= data[3:0];
        state <= 0;
                                        default        :        state <= 0;
                                        endcase
        always @ (*)
                        if (!rst_n)
                                        seg = 8'b1111_1111;                //null
                                        case (data_temp)
                                        0        :        seg = 8'b1100_0000;                //d0
                                        1        :        seg = 8'b1111_1001;                //d1
                                        2        :        seg = 8'b1010_0100;                //d2
                                        3        :        seg = 8'b1011_0000;                //d3
                                        4        :        seg = 8'b1001_1001;                //d4
                                        5        :        seg = 8'b1001_0010;                //d5
                                        6        :        seg = 8'b1000_0010;                //d6
                                        7        :        seg = 8'b1111_1000;                //d7
                                        8        :        seg = 8'b1000_0000;                //d8
                                        9        :        seg = 8'b1001_0000;                //d9
                                        10        :        seg = 8'b1000_1000;                //dA
                                        11        :        seg = 8'b1000_0011;                //db
                                        12        :        seg = 8'b1100_0110;                //dC
                                        13        :        seg = 8'b1010_0001;                //dd
                                        14        :        seg = 8'b1000_0110;                //dE
                                        15        :        seg = 8'b1000_1110;                //dF
                                        default        :        seg = 8'b1111_1111;                //null
                                        endcase
 楼主| lcytms 发表于 2016-11-11 17:09:40 | 显示全部楼层
新建数码管数据预处理模块pre_seg7.v。
module pre_seg7 (clk, rst_n, data, flag, data6);
        input clk, rst_n;
        input [3:0] data;
        input flag;
        output reg [23:0] data6;
                        if (!rst_n)
                                        data6 <= 24'h000000;
                                        if (!flag)
                                                data6 <= data6;
                                                data6 <= {data6[19:0], data};
 楼主| lcytms 发表于 2016-11-11 17:13:29 | 显示全部楼层
新建top.v顶层模块,将以上三个模块都加入到top.v顶层模块中进行例化。
将top.v模块设置为顶层模块。
编写top.v模块如下。
module top (clk, rst_n, col, row, sel, seg);
        input clk, rst_n;
        input [3:0] row;
        output [3:0] col;
        output [2:0] sel;
        output [7:0] seg;
        wire [3:0] data;
        wire flag;
        wire [23:0] data6;
        key_pad k1 (.clk(clk), .rst_n(rst_n), .col(col), .row(row), .data(data), .flag(flag));
        pre_seg7 p1 (.clk(clk), .rst_n(rst_n), .data(data), .flag(flag), .data6(data6));
        seg7 s1 (.clk(clk), .rst_n(rst_n), .data(data6), .sel(sel), .seg(seg));
 楼主| lcytms 发表于 2016-11-11 17:16:01 | 显示全部楼层
参照.tcl文件设置好FPGA管脚
参照EP4CE10F17C8Nzx_1.tcl文件内容,对FPGA芯片管脚进行设置。
EP4CE10F17C8Nzx_1.tcl文件相关内容如下所示。FPGA芯片配置结果如图所示。
        #set_global_assignment -name FAMILY "Cyclone IV"
        #set_global_assignment -name DEVICE ep4ce10f17c8n
set_location_assignment PIN_E1    -to    clk
# KEY 轻触按键
set_location_assignment PIN_L3    -to   key[0]
# SEG7 x 8 七段数码管
set_location_assignment PIN_L6    -to   sel[2]
set_location_assignment PIN_N6    -to   sel[1]
set_location_assignment PIN_M7    -to   sel[0]
set_location_assignment PIN_T11   -to   seg[0]
set_location_assignment PIN_T10   -to   seg[1]
set_location_assignment PIN_T9    -to   seg[2]
set_location_assignment PIN_T8    -to   seg[3]
set_location_assignment PIN_T7    -to   seg[4]
set_location_assignment PIN_T6    -to   seg[5]
set_location_assignment PIN_T5    -to   seg[6]
set_location_assignment PIN_T4    -to   seg[7]
# KEY_BORD
set_location_assignment PIN_L15   -to col[0]
set_location_assignment PIN_N15   -to col[1]
set_location_assignment PIN_P15   -to col[2]
set_location_assignment PIN_T15   -to col[3]
set_location_assignment PIN_R14   -to row[0]
set_location_assignment PIN_R16   -to row[1]
set_location_assignment PIN_P16   -to row[2]
set_location_assignment PIN_N16   -to row[3]
 楼主| lcytms 发表于 2016-11-11 17:18:44 | 显示全部楼层
.sof文件下载到FPGA
全编译FPGA工程,生成.sof文件,连接至芯ZX-1开发板并上电。
打开Programmer通过Jtag口,将.sof文件下载到FPGA进行在线仿真。
.sof文件下载界面如下图所示。
 楼主| lcytms 发表于 2016-11-11 17:19:41 | 显示全部楼层
开发板运行效果
开发板运行效果如下图所示。
经检查,开发板运行效果与设计相符。
程序下载后,当键盘矩阵按下1位按键时,该数补充到显示的6位数的低位上,高位左移。
比如,数码管原来显示012345,如果键盘按下6,则数码管显示变为123456。
 楼主| lcytms 发表于 2016-11-11 17:20:44 | 显示全部楼层
好了,今天的课程就讲到这里。
通过今天的课程,我们学习了键盘矩阵的基本原理,并对键盘矩阵逻辑电路进行了建模、仿真,结合第四讲的数码管一起编写一个完整的演示逻辑,进行了下板检查。
希望大家掌握键盘矩阵的基本原理,并熟练运用Verilog语言编写驱动逻辑。
更复杂的知识和技巧我们将逐步通过后面的课程展现给大家。
课程到此结束,谢谢大家的关注!
Sunlife 发表于 2016-11-16 16:21:30 | 显示全部楼层
          感谢楼主分享
芙蓉王 发表于 2016-11-17 16:51:23 | 显示全部楼层
              感谢楼主
GMT+8, 2026-5-22 09:30 , Processed in 0.033855 second(s), 18 queries .
