查看: 1160|回复: 2
使用逻辑分析仪遇到的问题,求助
zhiweiqiang33 发表于 2017-3-7 09:58:37 | 显示全部楼层 |阅读模式
quartus11 用signaltap一直提示Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed in the device. The expected compatibility checksum value is 0xE3FFF908; the value read from device is 0x38DE162D
是怎么回事哦?
 楼主| zhiweiqiang33 发表于 2017-3-7 12:11:18 | 显示全部楼层
会吗,会的话解答以下
GMT+8, 2026-5-23 00:16 , Processed in 0.032166 second(s), 20 queries .
