查看: 1163|回复: 0
数码管不亮啊,求助求助!
zhiweiqiang33 发表于 2017-3-15 09:58:30 | 显示全部楼层 |阅读模式
我想让数码管从000跳转到100;可是它直接不亮啊~求各位大神帮忙~
这是电路图
接着是程序:
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar temp,bai,shi,ge,tt;
void timer0()interrupt 1
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
tt++;
void init()
temp=0;
TMOD=0x01;
EA=1;
ET0=1;
TR0=1;
void delay(uint i)
uchar j;
while(i--)
for(j=0;j<125;j++)
void display(uchar bai,uchar ge,uchar shi)
P2=0xfe;
P0=table[bai];
delay(2);
P2=0xfd;
P0=table[shi];
delay(2);
P2=0xfb;
P0=table[ge];
delay(2);
void main()
init();//初始化~
while(1);
if(tt==20)
tt=0;
temp++;
if(temp==100)
temp=0;
bai=temp/100;
shi=temp%100/10;
ge=temp%10;
display(bai,shi,ge);
GMT+8, 2026-5-23 00:16 , Processed in 0.033117 second(s), 20 queries .
