查看: 1127|回复: 0
FPGA红外通信设计
fpga_feixiang 发表于 2017-3-21 09:47:36 | 显示全部楼层 |阅读模式
FPGA红外通信设计:
`timescale 1ns / 1ps
// Company:?
// Engineer: ? ? ? jiahua
// Create Date: ? ?15:49:43 10/29/2014?
// Design Name:?
// Module Name: ? ?commuication?
// Project Name:?
// Target Devices:?
// Tool versions:?
// Description:?
// Dependencies:?
// Revision:?
// Revision 0.01 - File Created
// Additional Comments:?
module commuication(
sys_clk ,
sys_rstn ,
data_tx ,
key ,
ir ,
sm_seg ,
sm_bit ,
led
input key;
input sys_clk;
input sys_rstn;
input ir;
output [7:0]sm_seg;
output sm_bit;
output data_tx;
output led;
wire key_done;
?light_tx u1 (
.sys_clk(sys_clk) ,
.sys_rstn(sys_rstn) ,
.data_tx(data_tx) ,
.key_done(key_done) ,
.send_data(send_data)
?key u3 (
.sys_clk(sys_clk),
.sys_rstn(sys_rstn),
.key(key),
.key_done(key_done),
light_dx u2
.sys_clk(sys_clk) ? ?,
? .sys_rstn(sys_rstn) ?,
? .ir(ir) ? ? ? ?  ,
? .sm_seg(sm_seg) ? ?  ,
? .sm_bit(sm_bit) ? ? ,
.r_data(r_data)
?correct u4(
.sys_clk(sys_clk),
.r_data(r_data),
.send_data(send_data),
.led(led)
module correct(
sys_clk,
r_data,
send_data,
led
input sys_clk;
input [7:0]r_data;
input [7:0]send_data;
output led;
assign led = (r_data == send_data)? 1'b1:1'b0;
// Company:?
// Engineer: jiahua
// Create Date: ? ?15:49:43 10/13/2014?
// Design Name:?
// Module Name:clock
// Project Name:clock
// Target Devices:?
// Tool versions:?
// Description:?
// Dependencies:?
// Revision:?
module key(
sys_clk,
sys_rstn,
key,
key_done
input  sys_clk;
input  sys_rstn;
input  key;
output  key_done;
wire  key;
wire  key_done;
//20ms ?50M=20NS 10^6
parameter ?t20ms = ?20'd1000_000;
reg [19:0]cnt;
wire key_start;
always@(posedge sys_clk )
if(!sys_rstn)
cnt <= 20'b0;
else if(key_start)
cnt <= 20'b0;
cnt <= cnt + 1'b1;
reg key_in;
reg key_in_next;
always@(posedge sys_clk)
if(!sys_rstn)
key_in <= 1'b1;
else?
key_in <= key;
key_in_next <= key_in;
assign key_start = key_in &(~key_in_next);
reg key2_in;
reg key2_in_next;
if(!sys_rstn)
key2_in <= 1'b1;
key2_in_next <= 1'b1;
else if(cnt == t20ms)
key2_in <= key_in;
else?
key2_in_next <= key2_in;
assign key_done= key2_in&(~key2_in_next);
// Company: ? ? ? ?
// Engineer: ? ? ??
// Create Date: ? ?11:07:14 02/27/2013?
// Design Name:?
// Module Name: ??
// Project Name:?
// Target Devices:?
// Tool versions:?
// Description:?
// Dependencies:?
// Revision:?
module light_dx
(sys_clk ? ?,
? sys_rstn ? ,
? ir ? ? ? ? ,
? sm_seg ? ? ,
? sm_bit ? ? ,
r_data
//杈撳叆銆佽緭鍑轰俊鍙锋帴鍙e畾涔??
input ? ? ? ? ?sys_clk ? ?;
input ? ? ? ? ?sys_rstn ? ;
input ? ? ? ? ?ir ? ? ? ? ;
output ?[7:0] ?sm_seg ? ? ;
output ? ? ? ? sm_bit ? ? ;
output  [7:0]r_data  ?;
//瀵勫瓨鍣ㄥ畾涔? ? ? ? ? ? ??
reg ? ? [7:0] ?sm_seg ? ? ;
reg ? ? [9:0] ?delay_cnt ?;
reg ? ? ? ? ? ?div_clk ? ?;
reg ? ? ? ? ? ?ir_reg0 ? ?;
reg ? ? ? ? ? ?ir_reg1 ? ?;
reg ? ? [8:0] ?ir_cnt ? ? ;
reg ? ? [4:0] ?rec_cnt ? ?;
reg ? ? [7:0] ?key_code ? ;
reg ? ? [31:0] data ? ? ? ;
wire ? ? ? ? ? sm_bit ? ? ;
wire ? ? ? ? ? ir_posedge ;
wire  ?  ? ir_negedge ;
wire ? ? ? ? ? t_9ms ? ? ?;
wire ? ? ? ? ? t_4ms ? ? ?;
wire ? ? ? ? ? low ? ? ? ?;
wire ? ? ? ? ? high ? ? ? ;
assign ? ? ? ? t_9ms=((9'd217 < ir_cnt)& (ir_cnt < 9'd297)) ;//257 ?
assign ? ? ? ? t_4ms=((9'd88 < ir_cnt) & (ir_cnt < 9'd168)) ;//128
assign ? ? ? ? low=((9'd22 < ir_cnt) & (ir_cnt < 9'd42)) ?;// 32
assign ? ? ? ? high=((9'd54 < ir_cnt) & (ir_cnt < 9'd74)) ?;// 63
assign ? ? ? ? ir_posedge=(~ir_reg1)&ir_reg0;
assign ? ? ? ? ir_negedge=ir_reg1&(~ir_reg0);
assign ? ? ? ? sm_bit = 1'b0;
//鐘舵?佹満瀹氫箟
reg ? ? [7:0] ?ir_state ? ;
parameter
? ? ?idle ? ? ? ? ?=8'h01 ?,
? waite_posedge =8'h02 ?,
? check_9ms ? ? =8'h04 ?,
? waite_negedge =8'h08 ?,
? check_4ms ? ? =8'h10 ?,
? rec_code ? ? ?=8'h20 ?;
//鏃堕挓鍒嗛??
always@(posedge sys_clk or negedge sys_rstn)
if(!sys_rstn)
delay_cnt<=10'd0;
div_clk<=1'b0;
else if(delay_cnt==11'd874)
delay_cnt<=10'd0 ;
div_clk<=~div_clk;
delay_cnt<=delay_cnt+1'b1 ;
div_clk<=div_clk;
//鎹曟崏绾㈠?栦?″彿鐨勪笂涓嬫部
always@(posedge div_clk or negedge sys_rstn)
if(!sys_rstn)
ir_reg0<=1'b0;
ir_reg1<=1'b0;
ir_reg0<=ir;
ir_reg1<=ir_reg0;
if(!sys_rstn)
ir_cnt<=9'd0;
rec_cnt<=5'd0;
key_code<=8'h0;
data<=32'h0;
ir_state<=idle;
case(ir_state)
idle:
if(~ir_reg0)
ir_state<=waite_posedge;
ir_cnt<=9'd0;
rec_cnt<=5'd0;
ir_state<=idle;
waite_posedge:
ir_cnt<=ir_cnt+1'b1;
if(ir_posedge)
ir_state<=check_9ms;
check_9ms:
if(t_9ms)
ir_state<=waite_negedge;
ir_cnt<=9'd0;
ir_state<=idle;
waite_negedge:
if(ir_negedge)
ir_state<=check_4ms;
check_4ms:
if(t_4ms)
ir_state<=rec_code;
ir_cnt<=9'd0;
ir_state<=idle;
rec_code:
if(ir_negedge)
rec_cnt<=rec_cnt+1'b1; ?
ir_cnt<=9'd0;
if(low)
data[rec_cnt] <= 1'b0;
else if(high)
data[rec_cnt] <= 1'b1;
ir_state<=idle;
if(rec_cnt==5'd31)
ir_state<=idle;
key_code<=data[23:16];
ir_state<=rec_code;
default:
ir_state<=idle;
endcase
assign r_data = data[23:16];
always @(key_code)
case (key_code) ?
8'h16 : sm_seg = 8'hc0; ? // "0"
8'h0c : sm_seg = 8'hf9; ? // "1"
8'h18 : sm_seg = 8'ha4; ? // "2"
8'h5e : sm_seg = 8'hb0; ? // "3"
8'h08 : sm_seg = 8'h99; ? // "4"
8'h1c : sm_seg = 8'h92; ? // "5"
8'h5a : sm_seg = 8'h82; ? // "6"
8'h42 : sm_seg = 8'hf8; ? // "7"
8'h52 : sm_seg = 8'h80; ? // "8"
8'h4a : sm_seg = 8'h90; ? // "9"
default:
? ?sm_seg = 8'hc0; ? // "0"
endcase?
? ? end
// Design Name:?
// Project Name:?
// Target Devices:?
// Tool versions:?
// Description:?
// Dependencies:?
// Revision:?
module light_tx(
sys_clk,
key_done,
sys_rstn,
data_tx,
send_data
input sys_clk;
input key_done;
input sys_rstn;
output [7:0]send_data;
output data_tx;
reg [7:0]send_data;
//閸掑棝顣剁拋鈩冩殶 ?50m t=20ns ? 1101_1011_1011_1010_0000_0 ??
reg [20:0]count;
reg clear;
parameter t9ms = 21'd449_999; ? ? ? ? ? ?//450000
parameter t4_5ms = 21'd224_999;  ?//225000
parameter t1_125ms = 21'd56_249;  ?//56250
parameter t0_56ms = 21'd27_999;  ?//28000
parameter t2_25ms = 21'd112_499;  ?//112500
parameter t1_678ms = 21'd83_899;  ?//83900
reg [2:0]n;
reg [2:0]m;
always @(posedge sys_clk or negedge sys_rstn)
if(!sys_rstn)
count <= 21'd0;
else if(clear)
count <= 21'd0;
else?
count <= count + 1'b1;
//div 38k ?1/38 ? 2.63157894 * 10^-5 ?s ? 26.3157us ?n=760 ?1110_1111_0110_0
//50Mhz 20ns?
//1khz  1ms ?1100_0011_0101_0000
parameter t1k ?= 15'd25000;
parameter t66k = 15'd379;?
parameter t38k = 15'd657;
reg [15:0]cnt_div;
reg div_switch;
reg clk_frequence;
always @(posedge sys_clk)
if(!sys_rstn)
cnt_div <= 16'd0;
clk_frequence <= 1'b1;
else if(div_switch)
if(cnt_div == t38k)
clk_frequence = ~clk_frequence;
cnt_div <=cnt_div + 1'b1;
cnt_div <= 16'd0;
reg [5:0]state;
reg [7:0]user_data;
reg [2:0]i;
reg [2:0]j;
reg data;
if(!sys_rstn)
state <= 6'd0;
case(state)
6'd0:
//if(key_done)
clear <= 1'b1;
user_data <= 8'b1111_1111;
state <= state + 1'b1;
send_data <= 8'b0000_0001;
div_switch <= 1'b0;
i <= 3'd0;
j <= 3'd0;
n <= 3'd0;
m <= 3'd0;
//else
//state <= 6'd0;
6'd1:
if(count == t9ms)
clear <= 1'b1;
div_switch <= 1'b0;
data  <= 1'd1;
clear <= 1'b0;
div_switch <= 1'b0;
6'd2:
if(count == t4_5ms)
clear <= 1'b1;
div_switch <= 1'b0;
clear <= 1'b0;
data ?<= 1'd0;
div_switch <= 1'b0;
6'd3,6'd4,6'd5,6'd6,6'd7,6'd8,6'd9,6'd10: ?//8娴e秵鏆熼幑
if(user_data[i] == 1'b0)
if(count == t1_125ms)
clear <= 1'b1;
i <= i + 1'b1;
div_switch <= 1'b0;
else if(count >= t0_56ms)
clear <= 1'b0;
data <= 1'b0;
div_switch <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b1;
if(count == t2_25ms)
clear <= 1'b1;
i <= i + 1'b1;
div_switch <= 1'b0;
data <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b0;
6'd11,6'd12,6'd13,6'd14,6'd15,6'd16,6'd17,6'd18:
if(user_data[j] == 1'b1)
clear <= 1'b1;
j <= j + 1'b1;
div_switch <= 1'b0;
clear <= 1'b0;
data <= 1'b0;
div_switch <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b1;
j <= j + 1'b1;
div_switch <= 1'b0;
data <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b0;
6'd19,6'd20,6'd21,6'd22,6'd23,6'd24,6'd25,6'd26:
if(send_data[n] == 1'b0)
clear <= 1'b1;
div_switch <= 1'b0;
n <= n + 1'b1;
clear <= 1'b0;
data <= 1'b0;
div_switch <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b1;
n <= n + 1'b1;
div_switch <= 1'b0;
data <= 1'b0;
div_switch <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b0;
6'd27,6'd28,6'd29,6'd30,6'd31,6'd32,6'd34,6'd35:
if(send_data[m] == 1'b1)
clear <= 1'b1;
div_switch <= 1'b0;
m <= m + 1'b1;
clear <= 1'b0;
div_switch <= 1'b0;
data <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b1;
div_switch <= 1'b0;
m <= m + 1'b1;
data <= 1'b0;
div_switch <= 1'b0;
clear <= 1'b0;
div_switch <= 1'b1;
clear <= 1'b0;
6'd36:
if(count == t1_678ms)
clear <= 1'b1;
div_switch <= 1'b0;
data <= 1'b0;
state <= 6'd0;
else?
div_switch <= 1'b1;
clear <= 1'b0;
default:
state <= 6'd0;
endcase
assign data_tx = (div_switch == 1'b1)? clk_frequence : data;
GMT+8, 2026-5-23 00:16 , Processed in 0.031493 second(s), 20 queries .
