查看: 1290|回复: 0
千兆以太网 TCP, UDP协议, FPGA实现
fpga_feixiang 发表于 2017-4-26 15:59:55 | 显示全部楼层 |阅读模式
这个工程由几部分组成, 外部使用了88e1111千兆以太网phy。FPGA内部有几个大的模块,
顶层模块:
    ////  tcpip_hw                                                    ////
    ////  Description                                                 ////
    ////      top module                                              ////
    ////  Author(s):                                                  ////
    ////      - bin qiu, qiubin@opencores.org or  chat1@126.com       ////
    ////                   Copyright (C) 2015                         ////
    `include "tcpip_hw_defines.sv"
    module tcpip_hw(
        input clk,
        input rst_n,
        output mdc,
        inout  mdio,
        output phy_rst_n,
        output is_link_up,
        input [7:0] rx_data,
        output logic [7:0] tx_data,
        input rx_clk,
        input rx_data_valid,
        output logic gtx_clk,
        input  tx_clk,
        output logic tx_en,
//user interface
        input [7:0] wr_data,
        input wr_clk,
        input wr_en,
        output wr_full,
        output [7:0] rd_data,
        input rd_clk,
        input rd_en,
        output rd_empty
    wire clk8;
    wire clk50;
    wire clk125;
    wire clk125out;
    wire is_1000m;
    logic eth_mode;
    always @(posedge clk50)
        eth_mode <= is_1000m;
    assign gtx_clk = clk125out;
    pll pll_inst(
        .inclk0(clk),
        .c0(clk50),
        .c1(clk125out),
        .c2(clk8)
    wire mdio_out;
    wire mdio_oe;
    wire reset_n;
    assign mdio = mdio_oe == 1'b1 ? mdio_out : 1'bz;
    rst_ctrl rst_ctrl_inst(
        .ext_rst(rst_n),
        .rst(reset_n),
        .clk(clk50)
    wire is_100m;
    wire is_10m;
    wire [7:0] tse_addr;
    wire tse_wr;
    wire [31:0] tse_wr_data;
    wire tse_rd;
    wire [31:0] tse_rd_data;
    wire tse_busy;
    headers_if if_headers_rx(clk50);
    headers_if if_headers_tx(clk50);
    ff_tx_if if_tx(clk50);
    ff_rx_if if_rx(clk50);
    frame_type_t rx_type;
    frame_type_t tx_type;
    logic rx_done;
    logic [31:0] data_recv;
    logic [15:0] data_recv_len;
    logic data_recv_valid;
    logic data_recv_start;
    logic rx_done_clear;
    u32_t cur_ripaddr;
    u16_t cur_rport;
    u16_t rx_header_checksum;
    logic need_ack;
    logic [7:0] flags;
    logic tx_start;
    logic [13:0] tx_dword_count;
    logic fifo_rdreq;
    logic [31:0] fifo_q;
    logic fifo_empty;
    logic pkt_send_eop;
    logic [15:0] data_send_len;
    logic [10:0] wr_addr_synced;
    rx_ram_in_if if_rx_ram_in();
    rx_ram_out_if if_rx_ram_out();
    tx_ram_out_if if_tx_ram_out();
    tx_ram_in_if if_tx_ram_in();
    logic [31:0] local_ipaddr;
    logic [31:0] remote_ipaddr;
    logic [31:0] remote_port_local_port;
    logic [1:0] op_mode;
    logic init_done;
    simple_mac_top simple_mac_top(
        .clk(clk50),
        .rst_n(reset_n),
        .mdc(mdc),
        .mdio_in(mdio),
        .mdio_out(mdio_out),
        .mdio_oe(mdio_oe),
        .phy_rst_n(phy_rst_n),
        .eth_mode(eth_mode),
        .rx_data(rx_data[7:0]),
        .tx_data(tx_data[7:0]),
        .rx_clk(rx_clk),
        .tx_clk(tx_clk),
        .clk125out(clk125out),
        .rx_data_valid(rx_data_valid),
        .tx_en(tx_en),
        .reg_addr(tse_addr),
        .reg_wr(tse_wr),
        .reg_wr_data(tse_wr_data),
        .reg_rd(tse_rd),
        .reg_rd_data(tse_rd_data),
        .reg_busy(tse_busy),
        .ff_rx_clk(clk50),
        .ff_rx_data(if_rx.ff_rx_data),
        .ff_rx_eop(if_rx.ff_rx_eop),
        .ff_rx_sop(if_rx.ff_rx_sop),
        .rx_err(if_rx.rx_err),
        .ff_rx_dval(if_rx.ff_rx_dval),
        .ff_rx_rdy(if_rx.ff_rx_rdy),
        .ff_tx_clk(clk50),
        .ff_tx_data(if_tx.ff_tx_data),
        .ff_tx_eop(if_tx.ff_tx_eop),
        .ff_tx_sop(if_tx.ff_tx_sop),
        .ff_tx_wren(if_tx.ff_tx_wren),
        .ff_tx_rdy(if_tx.ff_tx_rdy),
    data_source data_source_inst(
        .rst_n(reset_n),
        .wr_data(wr_data),
        .wr_clk(wr_clk),
        .wr_en(wr_en),
        .wr_full(wr_full),
        .rd_data(rd_data),
        .rd_clk(rd_clk),
        .rd_en(rd_en),
        .rd_empty(rd_empty),
    rx_ram rx_ram_inst(
        .rst_n(reset_n),
    tx_ram tx_ram_inst(
        .rst_n(reset_n),
        .overflow_flag(),
        .in_flush(),
    mac_config mac_config_inst (
        .clk(clk50),
        .rst_n(reset_n),
    assign pkt_send_eop = if_tx.ff_tx_eop;
    logic [3:0] next_parse_state;
    mac_rx_path mac_rx_path_inst(
        .rst_n(reset_n),
    mac_tx_path  mac_tx_path_inst (
        .rst_n(reset_n),
         .next_state(),
    eth_fsm eth_fsm_inst(
        .clk(clk50),
        .rst_n(reset_n),
        .state_counter(),
1.与外部phy芯片通信的模块,simple_mac模块。主要功能是通过mdio配置phy, 给发送帧打包(加入preamble,padding和crc32),和接收帧解包。 下面是顶层代码:
    ////  simple_mac_top                                              ////
    ////      top module of simple mac                                ////
    module simple_mac_top(
        input clk,
        input rst_n,
        output mdc,
        input  mdio_in,
        output mdio_out,
        output mdio_oe,
        output phy_rst_n,
        input eth_mode,
        input rx_clk,
        input tx_clk,
        input clk125out,
        output tx_en,
        input [7:0] reg_addr,
        input reg_wr,
        input [31:0] reg_wr_data,
        input reg_rd,
        output [31:0] reg_rd_data,
        output reg_busy,
        input  ff_rx_clk,
        output [31:0] ff_rx_data,
        output ff_rx_eop,
        output ff_rx_sop,
        output rx_err,
        output ff_rx_dval,
        input  ff_rx_rdy,
        input ff_tx_clk,
        input [31:0] ff_tx_data,
        input ff_tx_eop,
        input ff_tx_sop,
        input ff_tx_wren,
        output ff_tx_rdy
    assign phy_rst_n = rst_n;
    wire [7:0] rx_data_mac;
    wire rx_data_valid_mac;
    wire rx_sop_mac;
    wire tx_data_valid_mac;
    wire [7:0] tx_data_mac;
    wire [31:0] ff_tx_data0;
    wire ff_tx_eop0;
    wire ff_tx_sop0;
    wire ff_tx_wren0;
    wire [31:0] ff_rx_data0;
    wire ff_rx_eop0;
    wire ff_rx_sop0;
    wire ff_rx_dval0;
    wire tx_data_en;
    tx_header_align32 tx_header_align32_inst(
        .ff_tx_clk(ff_tx_clk),
        .rst_n(rst_n),
        .ff_tx_data0(ff_tx_data),
        .ff_tx_eop0(ff_tx_eop),
        .ff_tx_sop0(ff_tx_sop),
        .ff_tx_wren0(ff_tx_wren),
        .ff_tx_data(ff_tx_data0),
        .ff_tx_eop(ff_tx_eop0),
        .ff_tx_sop(ff_tx_sop0),
        .ff_tx_wren(ff_tx_wren0)
    rx_header_align32 rx_header_align32_inst(
        .ff_rx_clk(ff_rx_clk),
        .rst_n(rst_n),
        .ff_rx_data0(ff_rx_data0),
        .ff_rx_eop0(ff_rx_eop0),
        .ff_rx_sop0(ff_rx_sop0),
        .ff_rx_dval0(ff_rx_dval0),
        .ff_rx_data(ff_rx_data),
        .ff_rx_eop(ff_rx_eop),
        .ff_rx_sop(ff_rx_sop),
        .ff_rx_dval(ff_rx_dval)
    wire mac_tx_clk;
    assign mac_tx_clk = clk125out;
    simple_mac_rx_gmii rx_gmii_inst(
        .rx_clk(rx_clk),
        .rst_n(rst_n),
        .rx_data(rx_data),
        .rx_data_mac(rx_data_mac),
        .rx_data_valid_mac(rx_data_valid_mac),
        .rx_sop_mac(rx_sop_mac)
    simple_mac_tx_gmii gmii_tx_inst(
        .rst_n(rst_n),
        .tx_data_mac(tx_data_mac),
        .tx_data_valid_mac(tx_data_valid_mac),
        .tx_data_en(tx_data_en),
        .tx_clk(mac_tx_clk),
        .tx_en(tx_en),
        .tx_data(tx_data)
    logic [47:0] mac_addr;
    simple_mac_rx_path simple_mac_rx_path_inst(
        .rx_clk(rx_clk),
        .rst_n(rst_n),
        .mac_addr(mac_addr),
        .rx_sop_mac(rx_sop_mac),
       .ff_rx_data(ff_rx_data0),
       .ff_rx_eop(ff_rx_eop0),
       .ff_rx_sop(ff_rx_sop0),
       .rx_err(rx_err),
       .ff_rx_dval(ff_rx_dval0),
       .ff_rx_rdy(ff_rx_rdy)
    simple_mac_tx_path simple_mac_tx_path_inst(
        .rst_n(rst_n),
        .ff_tx_wren(ff_tx_wren0),
        .ff_tx_rdy(ff_tx_rdy),
        .tx_clk_mac(mac_tx_clk),
        .pkt_send_num()
    wire mdio_busy;
    wire [15:0] mdio_rd_data;
    simple_mac_phy_mdio phy_mdio(
        .clk(clk),
        .rst_n(rst_n),
        .mdc(mdc),
        .mdin(mdio_in),
        .mdout(mdio_out),
        .mdoe(mdio_oe),
        .phy_addr(5'b10000),
        .data_in(reg_wr_data[15:0]),
        .reg_addr(reg_addr),
        .wr(reg_wr),
        .rd(reg_rd),
        .data_out(mdio_rd_data),
        .busy(mdio_busy)
    wire [31:0] regs_rd_data;
    wire regs_busy;
    simple_mac_regs simple_mac_regs_inst(
        .clk(clk),
        .rst_n(rst_n),
        .data_in(reg_wr_data),
        .wr(reg_wr),
        .rd(reg_rd),
        .data_out(regs_rd_data),
        .busy(regs_busy),
    simple_mac_bus_arb simple_mac_bus_arb_inst(
        .mdio_busy(mdio_busy),
        .mdio_rd_data(mdio_rd_data),
        .regs_busy(regs_busy),
        .regs_rd_data(regs_rd_data),
        .reg_busy(reg_busy),
        .reg_rd_data(reg_rd_data)
GMT+8, 2026-5-23 01:02 , Processed in 0.033160 second(s), 20 queries .
