查看: 2672|回复: 1
给深度学习入门者的Python快速教程基础篇之十七
4798345 发表于 2017-5-22 18:28:44 | 显示全部楼层 |阅读模式
生成器(Generator)
生成器是迭代器的一种,形式上看和函数很像,只是把return换成了yield,在每次调用的时候,都会执行到yield并返回值,同时将当前状态保存,等待下次执行到yield再继续:
# 从10倒数到0
def countdown(x):
while x >= 0:
yield x
x -= 1
for i in countdown(10):
print(i)
# 打印小于100的斐波那契数
def fibonacci(n):
a = 0
b = 1
while b < n:
yield b
a, b = b, a + b
for x in fibonacci(100):
print(x)
生成器和所有可迭代结构一样,可以通过next()函数返回下一个值,如果迭代结束了则抛出StopIteration异常:
a = fibonacci(3)
print(next(a)) # 1
print(next(a)) # 1
print(next(a)) # 2
print(next(a)) # 抛出StopIteration异常
Python3.3以上可以允许yield和return同时使用,return的是异常的说明信息:
# Python3.3以上可以return返回异常的说明
def another_fibonacci(n):
a = 0
b = 1
while b < n:
yield b
a, b = b, a + b
return "No more ..."
a = another_fibonacci(3)
print(next(a)) # 1
print(next(a)) # 1
print(next(a)) # 2
print(next(a)) # 抛出StopIteration异常并打印No more消息
fpga_feixiang 发表于 2024-7-8 14:31:13 | 显示全部楼层
6
GMT+8, 2026-6-11 16:32 , Processed in 0.103197 second(s), 20 queries .
