查看: 1312|回复: 0
DES算法的VerilogHDL实现原理
小舍YZ 发表于 2017-8-22 15:49:21 | 显示全部楼层 |阅读模式
     拟采用模块化设计思想,根据DES算法的流程分模块设计实现各模块,自顶向下最终实现DES加密算法。
整体结构框架搭建,实现总体功能
module  DES(input clk,
    input des_enable,
    input reset,
    input des_mode,
    input [1:64] data_i,
    input [1:64] key_i,
    output wire [1:64] data_o,
output ready_o);
wire [3:0] inter_num_curr;
wire [1:32] R_i_var, L_i_var;
wire [1:56] Key_i_var_out;
wire [1:64] data_o_var_t;
wire [1:32] R_i, L_i;
wire [1:32] R_o, L_o;
wire [1:56] Key_o;
wire [1:28] C0, D0;
IP IP1(.in(data_i),
       .L_i_var(L_i_var),
       .R_i_var(R_i_var));
IP_ni IP_ni(.in(data_o_var_t),
            .out(data_o));
pc_1 pc_1(.key_i(key_i),
          .C0(C0),
          .D0(D0));
//F(R,K)
des_f  des_f1(.clk(clk),
              .reset(reset),
        .des_mode(des_mode),
              .inter_num_i(inter_num_curr),
              .R_i(R_i),
        .L_i(L_i),
        .Key_i(Key_i_var_out),
  .R_o(R_o), .L_o(L_o),
        .Key_o(Key_o));
//contral 16 F(R,K)
contrl contrl1(.data_o_var_t(data_o_var_t),
         .inter_num_curr(inter_num_curr),
             .Key_i_var_out(Key_i_var_out),
             .R_i(R_i),
             .L_i(L_i),
             .ready_o(ready_o),
             .L_o(L_o),
             .R_o(R_o),
             .R_i_var(R_i_var),
             .L_i_var(L_i_var),
           .Key_o(Key_o),
             .C0(C0),
             .D0(D0),
             .clk(clk),
             .reset(reset),
       .des_enable(des_enable));
GMT+8, 2026-5-23 06:06 , Processed in 0.032077 second(s), 20 queries .
