查看: 1359|回复: 0
f函数的实现
小舍YZ 发表于 2017-8-22 15:51:12 | 显示全部楼层 |阅读模式
f函数的实现
module des_f(input clk,
     input reset,
     input des_mode,
     input [3:0] inter_num_i,
     input [1:32] R_i,
     input [1:32] L_i,
     input [1:56] Key_i,
     output reg [1:32] R_o,
     output reg [1:32] L_o,
     output reg [1:56] Key_o);
reg [1:32] next_R;
//reg [31:0] R_i_var;
wire [1:48] expandedR;
reg [1:56] pre_key;
reg [1:48] new_key_tmp;
reg [3:0] inter_num;
wire [1:32] p;
reg [1:48] address_s;
reg [1:32] Soutput;
wire [1:32] Soutput_wire;
wire [1:48] new_key;
wire [1:56] out_key;
key_get  key_get(.pre_key(pre_key), .des_mode(des_mode), .inter_num(inter_num), .new_key(new_key), .out_key(out_key));
s1  sbox1(.stage1_input(address_s[1:6]), .stage1_output(Soutput_wire[1:4]));
s2  sbox2(.stage1_input(address_s[7:12]), .stage1_output(Soutput_wire[5:8]));
s3  sbox3(.stage1_input(address_s[13:18]), .stage1_output(Soutput_wire[9:12]));
s4  sbox4(.stage1_input(address_s[19:24]), .stage1_output(Soutput_wire[13:16]));
s5  sbox5(.stage1_input(address_s[25:30]), .stage1_output(Soutput_wire[17:20]));
s6  sbox6(.stage1_input(address_s[31:36]), .stage1_output(Soutput_wire[21:24]));
s7  sbox7(.stage1_input(address_s[37:42]), .stage1_output(Soutput_wire[25:28]));
s8  sbox8(.stage1_input(address_s[43:48]),  .stage1_output(Soutput_wire[29:32]));
always @(posedge clk or negedge reset)
if(reset == 1'b0)
R_o <= 32'd0;
L_o <= 32'd0;
Key_o <= 56'd0;
Key_o <= out_key;
if(inter_num == 4'b1111)
R_o <= R_i;
L_o <= next_R;
R_o <= next_R;
L_o <= R_i;    end
assign  expandedR =
                                        {R_i[32],R_i[1],R_i[2],R_i[3],R_i[4],R_i[5],
                                        R_i[4],R_i[5],R_i[6],R_i[7],R_i[8],R_i[9],
                                        R_i[8],R_i[9],R_i[10],R_i[11],R_i[12],R_i[13],
                                        R_i[12],R_i[13],R_i[14],R_i[15],R_i[16],R_i[17],
                                        R_i[16],R_i[17],R_i[18],R_i[19],R_i[20],R_i[21],
                                        R_i[20],R_i[21],R_i[22],R_i[23],R_i[24],R_i[25],
                                        R_i[24],R_i[25],R_i[26],R_i[27],R_i[28],R_i[29],
                                        R_i[28],R_i[29],R_i[30],R_i[31],R_i[32],R_i[1]};
assign  p = {        Soutput[16],Soutput[7],Soutput[20],Soutput[21],
                                        Soutput[29],Soutput[12],Soutput[28],Soutput[17],
                                        Soutput[1],Soutput[15],Soutput[23],Soutput[26],
                                        Soutput[5],Soutput[18],Soutput[31],Soutput[10],
                                        Soutput[2],Soutput[8],Soutput[24],Soutput[14],
                                        Soutput[32],Soutput[27],Soutput[3],Soutput[9],
                                        Soutput[19],Soutput[13],Soutput[30],Soutput[6],
                                        Soutput[22],Soutput[11],Soutput[4],Soutput[25]};
always @(*)
                        pre_key = Key_i;
                        inter_num = inter_num_i;
                        new_key_tmp = new_key;
                        address_s = new_key_tmp ^ expandedR;
                        Soutput = Soutput_wire;
                        next_R = (L_i^p);
GMT+8, 2026-5-23 07:02 , Processed in 0.032361 second(s), 21 queries .
