查看: 1491|回复: 3
迭代控制程序的设计与代码
小舍YZ 发表于 2017-8-22 15:52:14 | 显示全部楼层 |阅读模式
迭代控制程序的设计与代码
module contrl(output [1:64] data_o_var_t,
              output reg [3:0] inter_num_curr,
                                  output reg [1:56] Key_i_var_out,
                                  output reg [1:32] R_i, L_i,
                                  output reg ready_o,
                                  input [1:32] L_o,
                                  input [1:32] R_o,
                                  input [1:32] R_i_var, L_i_var,
                                  input [1:56] Key_o,
                                  input [1:28] C0, D0,
                                  input clk, reset, des_enable);
   reg [3:0] inter_num_next;
   assign data_o_var_t = (ready_o == 1'b1)?{L_o,R_o}:64'hzzzzzzzzzzzzzzzz;
        always @(posedge clk or negedge reset)
                        if(reset == 1'b0)
                                        inter_num_next <= 4'd0;
                                        inter_num_curr <= 4'd0;
                                        ready_o <= 1'b0;
                        else  if(des_enable)
                                        if(ready_o == 1'b0)
                                                inter_num_curr <= inter_num_next;
                        if(reset == 1'b0) ready_o <= 1'b0;
                        else if(inter_num_curr == 4'd15)  ready_o <= 1'b1;
                        else ready_o <= 1'b0;
        always @(*)
                        case(inter_num_curr)
                                4'd0:begin
                                //ready_o = 1'b0;
                                         R_i = R_i_var;
                                         L_i = L_i_var;
                                         Key_i_var_out = {C0, D0};
                                         inter_num_next = 4'd1;
                                4'd1: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                Key_i_var_out = Key_o;
                                                inter_num_next = 4'd2;
                                4'd2: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd3;
                                4'd3: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd4;
                                4'd4: begin
                                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd5;
                                4'd5: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd6;
                                4'd6: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd7;
                                4'd7: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd8;
                                4'd8: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd9;
                                4'd9: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd10;
                                4'd10: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd11;
                                4'd11: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd12;
                                4'd12: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd13;
                                4'd13: begin
                                //ready_o = 1'b0;
                                                R_i = R_o;
                                                L_i = L_o;
                                                inter_num_next = 4'd14;
                                4'd14: begin
                                //ready_o = 1'b0;
                                                        R_i = R_o;
                                                        L_i = L_o;
                                                        inter_num_next = 4'd15;
                                4'd15:if(ready_o == 1'b0)
                                                         R_i = R_o;
                                                         L_i = L_o;
                                                //ready_o = 1'b1;
                         endcase
FPGA_one 发表于 2017-8-23 09:48:44 | 显示全部楼层
学到了
晓灰灰 发表于 2017-8-23 11:09:49 | 显示全部楼层
迭代控制程序的设计与代码
 楼主| 小舍YZ 发表于 2017-8-23 13:02:59 | 显示全部楼层
GMT+8, 2026-5-23 06:06 , Processed in 0.032800 second(s), 20 queries .
