查看: 2284|回复: 1
一个三分频的电路却变成4分频
小泡泡 发表于 2010-4-20 19:08:25 | 显示全部楼层 |阅读模式
在用MAX+plusII设计一个产品时发现仿真结果不正确, 一个三分频的电路却变成4分频. 最后发现删除所有的cnf文件就行了. cnf文件有什么用?能否自行删除?
答:The MAX+PLUS II software creates . cnf files to reduce compile times. With the . cnf files, the compiler does not have to re-extract the design files every time the software recompiles a design.
The MAX+PLUS II Database Builder can determine if a given entity, with a given set of parameters and port usage, has already been extracted. If so, it saves time by just reading the . cnf file information from the disk.
If the . cnf files are deleted after each compile, the MAX+PLUS II software will call the extractors for every source file, which may cause an increase in the compile time.
The number of . cnf files generated depends on the design size and parameters. Once the . cnf files are created, they are not overwritten by the MAX+PLUS II software unless there is a design/parameter change. This could affect all the . cnf files initially generated by the MAX+PLUS II software. (参考译文:MAX+PLUS II软件创建. cnf文件以缩短编译时间. 有了. cnf文件, 编译器就不必在每次软件重新编译设计时重新抽取设计文件了.
MAX+PLUS II数据库构建器可以确定某个带有一组指定参数和端口使用的给定实体是否已被抽取. 如果是, 那么只要从盘中读取. cnf文件信息就可以了, 因而节省了时间.
如果在每次编译结束后都删除. cnf文件, 则MAX+PLUS II软件将为每个源文件调用抽取程序, 这可能导致编译时间的增加.
生成的. cnf文件的数量取决于设计的大小和参数. 一旦创建了. cnf文件, MAX+PLUS II软件就不会覆盖这些文件, 除非设计或参数发生改变. 这会影响所有最初由MAX+PLUS II软件生成的. cnf文件. )
CPLD 发表于 2011-7-3 10:17:14 | 显示全部楼层
GMT+8, 2026-5-23 22:10 , Processed in 0.032060 second(s), 20 queries .
